When I try to download an e-book from my local library I get the following message:
Error getting License. License Server Communication Problem:
E_ACT_NOT_READY
I tried the suggestion of de-authorizing the computer authorization but I when I go to enter the Vendor ID and password, it says my password is incorrect even after I reset it. Any suggestions? Thanks
Is that related to Adobe Digital Editions?
Yes it is. Have you had this issue?
No, but your discussion was in the Acrobat Reader forum.
[discussion moved to Adobe Digital Editions forum]
Hello,
Please make sure caps-lock is on or off depending on your passwrd.
If you are getting the error as "Incorrect password" then there is some mistake in entering the password.
I did. I can sign-in on the adobe ereader site using my username and passsword, but it does not work when I try to de-authorize it.
ok, i will give you the steps to de-authorize, but for authorization you will require the password which has to be correct.
Mac:
1. Go-> Go to folder.
Go to folder dialog will appear.
2. Type ~/Library/Application Support/Adobe/Digital Editions
drag the activation.dat file to the trash.
ADE will be deauthorized now.
Now Authorize ADE again.
Windows:
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key:
HKEY_CURRENT_USER\Software\Adobe\Adept
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Your authorization will be deleted.
Do you know of anyway to reset my account?
Follow below url:
https://helpx.adobe.com/contact.html?product=digital-editions&topic=signing-in-to-my-account
Select Digital Editions for step 1 and Adobe ID and signing in for step 2.
Click Still need help? Contact us.
When the option appears, click Chat now.
