Flex and ORACLE
Avatar
Level 1
I am new to Flex and I am impressed with the ease of use and
the presentation capabilities but I need to know the easiest way to
connect to an ORACLE database, because I want to use it to build a
prototype for a financial application. I don't have much experience
in this area and was hoping there would be a straight-forward way
to achieve this?
I have installed ORACLE 10g express, Flex Builder 2 and
LiveCycle Data Services (formerly Flex Data Services), with
integrated JRun application server.
What should I do next? I would be grateful for any advice.
Thanks, Antony
Avatar
Level 1
If you get a solution please inform me because I have the
same problem
Avatar
Former Community Member
I'll ask whether Oracle 10g Express is supported and report
back. However,
although not for this exact server, have you seen any of the
instructions
at this location?
http://help.adobe.com/en_US/livecycle/es/lcds_installation.html#oc4j
Avatar
Sorry, I see that you're actually asking how to use Flex to
contact an Oracle
database.
There are couple of options....
You could use a J2EE application server and write either JSP
pages or a Java
Servlet to do data base queries on your behalf using JDBC and
return XML
to the Flex client using <mx:HTTPService>.
Or, you could similarly use LCDS and connect to a plain old
java object (that
also uses JDBC) that you configure as a remoting service
destination and
contact it using <mx:RemoteObject>. The difference here
is that you'll get
better performance and be able to return strongly typed
objects back to ActionScript.
Or, you could use a nifty feature like LCDS's data management
services with
its SQLAssembler where you configure a destination and
parameterized SQL
statements and not have to write any server side code.
Avatar
Level 1
Perfect Mr. Newsgroup. You make things become little bit
clearer to me, but I am bignner in Flex so I am looking for you to
give me an example of How I can do that? I want an example of any
kind you give it to me. I tried to understand samples on lcds ,but
I failed. I copy the code in a new mxml and run it, but it shows me
many errors in the <mx:DataService> I don't know why?
Flex project must be in a specified path or what???
Please Help me with an easy example.
Thank You
Avatar
Level 2
Probably. Are you deploying your app locally or in the LCDS
localhost? 'Cause if you are not on LCDS any HTTPService would
never work.
Mr. Farland, I'm expecting you to explain us alittle bit
further the techniques, plus you have to consider the people that
don't know jsp very well. I hope you can help us. Thank you.
Avatar
Level 1
Hi Peter,
Thanks for your advice. I am really looking for the easiest
way to connect to my database in order to build my prototype, so I
presume that the last option you suggest would be the best - the
less code I have to write the better!
Would this option scale up to a full intranet application
with say 10 users, or would I have to use some other set-up for the
full-blown system?
Any tips or links you can provide would be very gratefully
received.
Cheers Antony
