OOP "inheritance"
Participant ,
Jul 16, 2007 Jul 16, 2007
I have component base class, I'll call Obj1
and I have another component parent class that extends Obj1, I'll call Obj2.
I have two functions in each, both with same names in each using function overriding.
In Obj1
Function A calls Function B
In Obj2
Function B calls Function C
Function C calls Super.A() which is (Obj1->A)
From there Obj1->A should call Obj1->B, but it isn't. It's calling Obj2->B, and thus I get an infinite loop. How is it that Obj1 even knows about Obj2?
I was originally calling from Obj1 <cfset B()> and I tried <cfset this.B()> but both get the same results.
I know I've tried this a while ago when using Application inheritance for sub-modules, and I was getting different behavior when I wanted to do a refresh onRequestStart with URL.request and calling sub-modules OnSessionStart and OnApplicationStart, but it was only calling the base Application. I'm a bit confused on why the change in behavior, or if I'm not understanding things.
Advanced techniques
365
This is where you perhaps start confusing yourself. Class != object. A
class defines what it is to be an object; an object is a "realisation" of
that class.
In CF there are no classes, but the closest parallel is a CFC file. Not a
CFC *instance*, but the file itself, in the file system.
Similarly in CF there aren't "objects", really, but the closest parallel is
a CFC instance (as created by createObject(), <cfobject> or <cfinvoke>).
Objects reside in memory, not in the file system.
No, because if you have this:
o = create("component", "Obj2");
then o is an Obj2. It's not "part Obj2 and part Obj1, depending on which
line of code is being executed". It doesn't matter whether the methods are
defined in Obj2 or Obj1; the object itself is an Obj2.
When you call a method, CF doesn't look for a method of that name *in the
current CFC file*, it looks for a method of that name *in the object*. And
because it's an Obj2, it will "see" the b() method of Obj2, even if the
code being executed is in Obj1.cfc.
Make sense?
Adam
Participant ,
Yes thanks for the clarification.
I guess its back to the drawing board ... tomorrow.
Participant ,
Jul 17, 2007 Jul 17, 2007
Follow on question:
Does then Super.function() only work on 'top' object?
Example: (using above names but adding a Obj3)
Obj1->A()
- does something
Obj2->A()
- calls Super.A()
Obj3->A()
- calls Super.A()
Does this work as intended?
My usual advice when people ask questions like this is...
... did you try it? Did it seem to work? If it didn't seem to work, in
what way did it seem to not work?
And a bit of reading is always helpful too:
http://livedocs.adobe.com/coldfusion/7/htmldocs/00001059.htm
Adam
Documentation
