Hi Daverms,
Just tried your solution and get the following:
Complex object types cannot be converted to simple values.
The expression has requested a variable or an intermediate
expression result as a simple value, however, the result cannot be
converted to a simple value. Simple values are strings, numbers,
boolean values, and date/time values. Queries, arrays, and COM
objects are examples of complex values.
The most likely cause of the error is that you are trying to
use a complex value as a simple one. For example, you might be
trying to use a query variable in a <CFIF> tag. This was
possible in ColdFusion 2.0 but creates an error in later versions.
The error occurred in
D:\cfmx\cfdev_working_folder\UKCHAPP40\dsp_LeftMenuModule.cfm: line
17
15 :
16 : <cfoutput>
17 : <cfset TemplatesAndForms=application.menuWords &
".#session.MyLanguage#." & TemplatesAndForms>
18 : </cfoutput>
19 :
any ideas?
matrix
