Hi Colum,
Thanks for the response. I did as you suggested and added
glossary definitions and then ran the glossary wizard to assign
them. I removed all references to the old glossary from both the
main and subprojects (TOC, Index, Baggage, output folders, etc). I
generated the main project, and then searched for glossary. I got
two results, both of which link to the Window's glossary and a
Runtime Error asking me if I want to Debug. Any ideas?
I cannot find the Glossary Hotspot Editor you mention in your
response. I only see the Glossary Hotspot Wizard or the Browse
Sequence Editor. I'm not convinced with the results, since I prefer
a popup over expanding text, and I could format my old popups with
returns and bullets. However, my boss says that if the wizard takes
care of the problem, then that is what we will use, but so far it
hasn't.
Jennifer
