Locked
install warns connection error
Guest
Apr 24, 2015 Apr 24, 2015
HELP!!!
was trying to update the flash player ,it went well to download but when to start install it warns me "connection error" but i test my internet working just fine, i tried and restart my mac lots of time , still the same problem ! my mac is 10.9.5
please help, whats wrong with it ? i even uninstall the flash player and try to start over from the very first step , but still no GOING NUTS
897
Guest
just found the solution
download the offline installer
http://fpdownload.macromedia.com/pub/flashplayer/latest/help/install_flash_player_osx.dmg
and restart mac after you download it successfully then you can update to the latest flash player
Apr 25, 2015 Apr 25, 2015
Flash is doing the exact thing with me only thing is i'm using Windows XP and FireFox which is incompatible with offline installers
Adobe Employee ,
Apr 27, 2015 Apr 27, 2015
Hi tylerxx,
What version of Firefox are you using?  Does your XP system have Service Pack installed, if so what version?
Maria
Guest
May 06, 2015 May 06, 2015
Latest Firefox 37.0.2
XP sp2
Same issue
Adobe Employee ,
Hi mrsirismoon,
This is the online installer that is failing to download the installer in the background.  The connection error could be caused by a few different issues, I'd like to obtain some log files from you.  Please do the following to obtain the log files:
  1. Create an empty text file named ADM.trace inside your %temp% directory, on XP, this is usually located at C:\Documents and Settings\labuser\Local Settings\Temp for XP
    • Run the online installer again
    • After the connection error returns, provide the following log files using the instructions here How to share a document:
      • The ADM.trace file created in step 1
      • The two log files saved at C:\Users\YourUserID\AppData\Local\Temp\Adobe_ADMLogs
    Also, when downloading the file are you saving it locally or do you select 'Run' from the download/save dialog?  Do you have Virus protection and/or Firewall configured on your system?  If so, which programs do you have installed?
    The Windows offline installers are posted at the bottom of the Installation problems | Flash Player | Windows page in the 'Still having problems' section.
    Maria
    Adobe Employee ,
    Hi tylerxx,
    Offline installers are compatible with Windows XP as XP is still a supported platform.
    Maria
