It appears that Adobe's new(last month or so) silver installer program is unable to read the system proxy settings and can not download the full program. I have the same issue with Reader and Flash. I was forced to get a distribution agreement and then was able to download a full version of both products.
We are running Win7 Pro SP1 in a corporate environment using a proxy server.
Lyle Giese
Chase Products Co.
Hi Carolyn,
Kindly check if the below mentioned links are white-listed in your network.
Address | Ports | |
ccmdls.adobe.com | 443 | |
ims-na1.adobelogin.com | 80 | 443 |
ims-prod06.adobelogin.com | 443 | |
na1r.services.adobe.com | 80 | 443 |
prod-rel-ffc-ccm.oobesaas.adobe.com | 443 | |
prod-rel-ffc.oobesaas.adobe.com | 443 | |
lm.licenses.adobe.com | 80 | 443 |
ccmdl.adobe.com | 80 | |
swupmf.adobe.com | 80 | |
swupdl.adobe.com | 80 | |
prod.acp.adobeoobe.com | 443 | |
interaction.adobe.com | 443 |
Kindly share the screenshot of the message, also let us know which products are your trying to install.
You can also try the alternate link to download the Adobe software: Adobe CC 2014 Direct Download Links: Creative Cloud 2014 Release | ProDesignTools
Atul Saini
We get this with both the Reader DC and Flash. When the updater was the black app, we had no problems.
We have no blocks on any of the sites/ports you mentioned about and can reach them manually when testing.
Hi ctoren,
I'd like to get some log files from you to investigate further. Please do the following:
Also, when downloading the file are you saving it locally or do you select 'Run' from the download/save dialog?
Thank you in advance.
Maria
This was taken via firefox on a Win7 machine and we select to save locally and then run from the download directory.
I created the logs as requested and looked at the file Adobe_ADM.log and it's obvious at least to me where the issue lays. Here are a couple of lines from that log:
05/01/15 12:46:33:097 | [TRACE] | | ADM | | WorkflowManager | | | 6220 | HTTPConnector::HTTPSend
05/01/15 12:46:33:103 | [DEBUG] | | ADM | | ApplicationContext | | | 6220 | GetIEProxyInfo - No default proxy present on the user machine
05/01/15 12:46:33:103 | [INFO] | | ADM | | ApplicationContext | | | 6220 | GetIEProxyInfo - autoconfig url on the machine is :http://10.0.100.236/proxy.pac
05/01/15 12:46:33:109 | [INFO] | | ADM | | ApplicationContext | | | 6220 | GetIEProxyInfo - Failed to get proxy for the url, error:12006
05/01/15 12:46:54:216 | [DEBUG] | | ADM | | ApplicationContext | | | 7052 | WINHTTP_CALLBACK_STATUS_REQUEST_ERROR...
05/01/15 12:46:54:216 | [WARN] | | ADM | | WorkflowManager | HttpConnector | | 7052 | WINHTTP_CALLBACK_STATUS_REQUEST_ERROR : error : 12002
05/01/15 12:46:54:216 | [TRACE] | | ADM | | WorkflowManager | | | 6220 | HTTPConnector::HTTPSend :: After callback : error Type : -190, error code : 12002
05/01/15 12:46:54:216 | [FATAL] | | ADM | | WorkflowManager | HTTPConnectorError | | 6220 | Error occurred while getting application xml: -190 extended error: 12002
05/01/15 12:46:54:216 | [DEBUG] | | ADM | | ApplicationContext | | | 6220 | Showing screen: initErrorScreen
We use a centralized proxy.pac to configure the proxy for our users browsers. The proxy.pac is as follows:
function FindProxyForURL(url, host){
if (isPlainHostName(host))
{return "DIRECT";}
else if (isInNet(host, "10.0.0.0", "255.255.0.0"))
{return "DIRECT";}
else if (isInNet(host, "10.10.0.0", "255.255.255.0"))
{ return "DIRECT";}
else if (isInNet(host, "127.0.0.0", "255.0.0.0"))
{ return "DIRECT";}
else if (shExpMatch(host, "mail.chaseproducts.com"))
{ return "DIRECT";}
else if (shExpMatch(host, "mail2.chaseproducts.com"))
{ return "DIRECT";}
else if (shExpMatch(host, "mail3.chaseproducts.com"))
{ return "DIRECT";}
else if (shExpMatch(host,"chasew12s*"))
{ return "DIRECT";}
else if (shExpMatch(host, "chasew8s*"))
{ return "DIRECT";}
else if (url.substring(0, 5) == "http:")
{return "PROXY 10.0.100.240:3128";}
else if (url.substring(0, 4) == "ftp:")
else if (url.substring(0, 6) == "https:")
else
Hi ctoren,
Thank you for the information. I have forwarded it to the folks that handle the online installer.
Maria
