Show 18 replies
1. Re: Center problem
Newsgroup_User Nov 26, 2007 8:52 AM (in response to joe dora)I'm curious why you use this file nomenclature -
<link href="!!_css/ahim.css" rel="stylesheet" type="text/css" />
<link href="!!_css/new_ccc_fonts.css" rel="stylesheet" type="text/css" />
Your 'centering' code is a bit confused. You have this -
#container { width:100%; margin:0 auto; }
If something is 100% wide, you cannot center it as you have tried here.
So - how do you want this to behave? The way it does in IE?
By the way, there is no such thing as font-weight:400; - all you get are
'normal' or 'bold'.
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
"joe dora" <webforumsuser@macromedia.com> wrote in message
news:fiet4a$k72$1@forums.macromedia.com...
> Site location for review:
> http://usersite.com/ahimsahaven
> New site about to turn over to client.
> Works okay but main container not centered in Firefox or Netscape 8
> Center okay with internet explorer 7
> Main container contains a table which contains the content
2. Re: Center problem
Newsgroup_User Nov 26, 2007 8:57 AM (in response to joe dora).oO(Murray *ACE*)
There is:
http://www.w3.org/TR/CSS21/fonts.html#propdef-font-weight
Micha -
3. Re: Center problem
Newsgroup_User Nov 26, 2007 8:58 AM (in response to joe dora)I mean in the practical sense. It's not supported by the browsers. Normal
and bold is all you get in any reliable way. As I recall, normal is 300,
and bold is 900.
"Michael Fesser" <netizen@gmx.de> wrote in message
news:okulk396jl23jfv3itgnsab94l2vjq1gmj@4ax.com...
> .oO(Murray *ACE*)
> There is:
> Micha
4. Re: Center problem
Newsgroup_User Nov 26, 2007 9:13 AM (in response to joe dora).oO(Murray *ACE*)
OK. ;)
>and bold is 900.
Quite possible. I've never used the numerical values, mainly because it
doesn't make much sense in normal text. Even in a heading, which might
be a bit bigger, the difference between normal and bold is maybe 2 or 3
pixels, so most of the numeric font weights will simply look the same.
It's also a question of how the browser maps these different weights
onto the actual font.
There's some interesting stuff about these issues in the CSS spec.
Micha -
5. Re: Center problem
joe dora Nov 26, 2007 9:28 AM (in response to joe dora)I removed the width 100% but still the same. firefox not centered.
The exclamation marks cause the file to float to the top. I always know where they are.
I would like firedox and netscape 8 to position the same as IE7 -
6. Re: Center problem
Newsgroup_User Nov 26, 2007 10:19 AM (in response to joe dora)On Mon, 26 Nov 2007 17:29:21 +0000 (UTC), "joe dora"
The default is for a block level item, like a <div> tag, to be 100%
wide. If you want it to be centered, you must give it a specific width.
Try changing the width to about 770px.
>they are.
I understand your intent, but it worries me. I'd be afraid some browser
or other would ignore it. It's best to keep file and folder names to
letters a-z, numbers 0-9, the hyphen and the underscore.
Gary -
7. Re: Center problem
joe dora Nov 26, 2007 11:33 AM (in response to joe dora)I placed 770px in the box width. It did restrict the site horizontally and vertically. Though the site was restricted the editable part of the site remained on the left with Firefox. It was centered okay in ie. I put the 100% width back.
The 770px width did not change the position of the container.
Both IE and Firefox display the site the same. They fill the monitor.
But the light green portion where the editable content is displayed differently. IE displays the whole site with the editable content centered. Firefox displays the whole site but the editable content hugs the left part of the site. -
8. Re: Center problem
joe dora Nov 26, 2007 12:33 PM (in response to joe dora)I was in the wrong container.
Maincontainer Box has a width of 600px
margin left 15 ems margin right 20 px
I tried changing but got goofed up. All back to the wayI found them. -
9. Re: Center problem
Newsgroup_User Nov 26, 2007 1:33 PM (in response to joe dora)On Mon, 26 Nov 2007 20:33:57 +0000 (UTC), "joe dora"
All I can tell you is that it works if done correctly. I have no idea
where you are with it now.
Gary -
10. Re: Center problem
joe dora Nov 28, 2007 6:54 PM (in response to joe dora)Gary: Here is where I am right now.
!. I am looking for a sensible answer.
2. I did every thing correctly. Site works just the way I want it to with the Adobe Dreamweaver primary browser internet explorer. Client is delighted with its appearance and performance. (I am not.)
3. The site does not perform the way it should in Firefox and Netscape 8. The editable content container shifts to the left and also the image alternate text messages do not appear.
4. I do not know how to compensate for other browser deficiencies. I don’t have any idea where to look. I assumed Adobe dreamweaver expert technicians would.
5. Site will be published. If you don’t know how to correct the problem, it will be okay. Maybe some day all the browsers will get together and use the same rules
Site can be seen at http://usersite.com/ahimsahaven -
11. Re: Center problem
Newsgroup_User Nov 29, 2007 3:17 AM (in response to joe dora).oO(joe dora)
Never rely on the appearance in IE! It's an old and broken browser. Test
with standards-compliant browsers like Opera or Firefox, then fix for IE
if necessary.
This usually means that there's something wrong with the site.
>The
That's how it's supposed to be. If you want tooltips on your images or
any other elements, use a 'title' attribute. Of course the 'alt'
attribute is necessary as well, but not for a tooltip. IE gets it wrong,
as usual.
To center a block-level element, the usual way is to apply a width other
than 100% to it and to set its left and right margins to 'auto'. This
works even in IE 6 in standards mode. You might have to play around with
different margin or padding settings because of the floated side menu.
Some other things:
* The homepage is titled "index page" - a rather bad choice for a page
title.
* Your stylesheets are linked twice.
* There are also some validation errors that should be fixed:
http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fusersite.com%2Fahimsahaven%2F
Micha -
12. Re: Center problem
Newsgroup_User Nov 29, 2007 6:58 AM (in response to joe dora)On Thu, 29 Nov 2007 02:54:52 +0000 (UTC), "joe dora"
I'll try.
Okay.
I started looking at your CSS to see what was going on with the left
aligned content vs the centered content and I quickly got a headache.
Try this in IE6. Narrow your browser window to 800 pixels wide. Your
lovely centered content drops down below your left aligned menu.
It looks like you have way over-engineered the page. You've got three
separate style sheets, two of which are linked in twice. In some cases,
rules in one style sheet contradict rules in one of the other style
sheets. You have a rather basic, simple design. It shouldn't take 10k of
CSS to produce it.
As far as alternate text not being displayed, the fact that IE *does*
display it is yet another IE bug. The alternate text should only be
displayed when the image is *not* displayed. If you want a tool-tip to
pop up on mouse hover, use the title attribute.
> 4. I do not know how to compensate for other browser deficiencies. I don?t
>would.
The "other browser deficiencies" are that they tend to render pages
correctly, while IE is pretty badly broken. The first thing to
compensate for browser differences is to code to standards and test in a
standards compliant browser. Then fix what needs to be fixed to
compensate for the IE bugs.
Gary -
13. Re: Center problem
joe dora Nov 29, 2007 8:13 AM (in response to joe dora)Thank you for responding to my problem. I will try to make the changes you suggested. I just did a fast one and made firefox my default btowser. I guess I must have a microsoft computer because the first time I used fire fox it downloaded some kind of an update. From that point on all all I got was the microsoft error message. Fortunitly I had set a restore point b4 I set firefox as the default and I was able to restore it back to explorer.
This will take time. Thank you. I'll get back to you. -
14. Re: Center problem
Newsgroup_User Nov 29, 2007 1:58 PM (in response to joe dora)On Thu, 29 Nov 2007 16:13:16 +0000 (UTC), "joe dora"
There was a problem with XP when you tried to set something other than
IE as the default browser. I believe there was a Windows update that was
supposed to address that. That said, you don't really need to make
Firefox your default browser. I still have IE as my default browser on
my desktop machine, even though I almost never use it except for
testing. My wife likes to use it for some things she does. I just have
Firefox set as my primary browser in Dreamweaver.
Good luck!
Gary -
15. Re: Center problem
joe dora Jan 3, 2008 4:06 PM (in response to joe dora)Hi! I'm back again. I have resolved my problem with Firefox. I had a problem centering my site using Firefox and Netscape 8. I tinkered with the main content container right and left adjustments. I am sure I am still violating some CSS rules but it is working fine, the site is active, and me and my client are pleased. So that category as far as I am concerned is closed. You may review the site site at http://ahimsahaven.org I am proud of it.
I still have a problem with the alternate image tags. I have always used them and thought they were necessary for identification. They are working fine but you people claim that is a Microsoft Internet Browser error. I visited firefoxes knowledge base and they tell me to use a title attribute. I searched Dreamweaver and I seem to be opening up another can of worms.
Would you tell me in a simplified manner how to instruct Dreamweaver to write a title tip for my images that Firefox and Netscape will display? -
16. Re: Center problem
Newsgroup_User Jan 4, 2008 3:01 AM (in response to joe dora)On Fri, 4 Jan 2008 00:06:43 +0000 (UTC), "joe dora"
Dw sadly does not allow Design view to add image titles - all I can
suggest is to use find and replace to change site wide.
alt="image title"
to
alt="image title" title="image title" -
BUT BACKUP the whole site first.
I'm not sure that file path is a good idea - using " !!" - why do that
~Malcolm N....
17. Re: Center problem
joe dora Jan 6, 2008 1:44 PM (in response to joe dora)Good job. I applied “title” according to "Malcolm N" instructions.
I checked all with Firefox, Netscape and Internet Explorer.
All work great.
Please be aware that I appreciate the help I received from this forum. I started out Nov. 26 with an extremely complex problem. All problems are resolved and I am completely satisfied with the assistance I received.
I will close the request. However, I know I will be back with some new problem that I have yet to detect.
Thank you all.
Joe Dora -
18. Re: Center problem
joe dora Jan 8, 2008 4:10 PM (in response to joe dora)I just closed out my forum question and here I am again. I hope for the last time.
Site is running perfectly. It has received 1443 visits since turned up to traffic on December 12. I have received no complaints. But! Today a user notified me that she could not see the content and it had dropped out of the site. The site was visible but the content did not appear in it.
Upon investigation I found that in Internet Explorer if the display is shrunk it will reduced for a time and then the content will drop to the bottom of the page. It will drop completely off like it does not fit. The site remains visible. The top of the content is barely visible and Internet Explorer must be scrolled down to see it.
I tried this out in Netscape and Firefox and in both instances site reduces correctly. In Internet Explorer it does not.
Can you help me?
Also, what does a user do to cause this? There is more than enough space around the content to prevent this.
Site may be viewed at
http://ahimsahaven.org/
JD
