tracjerian wrote:
> I have a login script that verifies against a database.
The script verifies the
> user name and password.
> I need to verify the user type and then depending on the
user type send the
> user to one of two pages i.e. user type 1 would go to
index.cfm and user type 2
> would go to user.cfm.
> Any help would be greatly appreciated. here is my code:
> <cfquery name="qVerify" datasource="clients">
> SELECT TblUser.User_id, TblUser.User_Password,
TblUser.User_Type
> FROM TblUser, TblUserType
> WHERE user_id = '#username#' AND User_password =
'#password#'
> </cfquery>
not related to your direct question, but...
1) i would use a proper INNER JOIN in your query instead of
the
Cartesian join you are using
2) i would suggest scoping your username and password
variables and USE
CFQUERYPARAM!
> <cfif Verify.Recordcount>
> <cfset session.allowin = "True">
> <cfset SESSION.UserID = qVerify.user_id />
> <script>
> alert("Welcome! You have been successfully logged in!");
> self.location="Processors_Home.cfm";
> </script>
OK, so in order to tell which type current user is, you need
to either
store that info somewhere (like SESSION scope var) or query
your db each
time you need that info (not an optimal option).
I suggest you also store User-Type in the session scope (add
<cfset
SESSION.UserType = qVerify.User_Type> to the script block
above) and on
your Processor_Home.cfm page you will need to have an
cfif/cfelse block
to check the value of this var and cflocate to correct page.
> <cfelse>
> <script>
> alert("Your credentials could not be verified, please
try again!!");
> self.location="Javascript:history.go(-1)";
> </script>
> </cfif>
alternatively, you may want to look at the cf's LOGIN and
LOGINUSER
tags. Using the login framework gives you access to such
useful
functions as isUserInRole, getAuthUser, etc
hth
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
