Locked
3
can't align a stroke to inside
Participant ,
Apr 11, 2012 Apr 11, 2012
I 've created a shape (Rectangle) , Applied a rounded corners, expand appearance, and a linear gradient.
After that i added a stroke in the appearance panel (2pt wide), filled it with white and when I wanted to align this stroke to inside
I can't.  The options "Align Stroke to inside" "Align Stroke to Outside" are greyed out .
What's wrong ?
Thank you
Tools
191.6K
Community Expert , Apr 11, 2012 Apr 11, 2012
Following your steps, I suspect you added a stroke at the group level. At the group level your option will be greyed out. Yo need to ungroup after your expand appearance.
Try using the appearance panel often, there are many very important features there.
Adobe
It may be an open path although it looks like a closed path. Aligning strokes inside or outside does only work on closed paths.
Contributor ,
Dec 29, 2015 Dec 29, 2015
This is one of the dumber things that still somehow exist in Illustrator. Why? What if you only want a stroke on one segment of a path? I'd use that ALL the time. If I could put the stroke on one side or another of the actual path, closed or not, it would allow the same result. I love Illustrator but there is bafflingly stupid stuff that Adobe just seems to ignore. You can save the "you're using it wrong" comments. I get it.
Apr 22, 2016 Apr 22, 2016
I sympathize with SINRISE...Adobe tools should be more consistent in use across all products - INDD, AI, PSD, etc. The things you can do in one program, you can't do in another. [Grrrr...]
Mar 12, 2019 Mar 12, 2019
See fernandolins golden tip below
<a href="https://bassictraining.com">Learn bass guitar</a> & <a href="https://howtoiceacake.com">Decorate Cakes </a>
Things to do in your spare time:<br />
Jul 26, 2019 Jul 26, 2019
OMG. I was given a file with shapes in it that honestly looked like closed paths but when I double-checked the option to "Join" was available so I clicked it and voila all my problems went away! Thank you!
Dec 22, 2021 Dec 22, 2021
Ah, thanks!
You can easily achieve it with a custom width profile in version CS5
Advocate ,
Hi Kililio
If your shape is using brushes you cannot select align inside or outside (just to center). Also if you have a custom width profile you cannot select that align options too. But using width profiles (or the Width Tool) you could achieve the result you want..as Monika mentioned.
Best Regards
Gustavo.
Jan 10, 2017 Jan 10, 2017
Another user friendly feature from Adobe...
Participant ,
Apr 12, 2012 Apr 12, 2012
Thanks a bunch guys !!!
@Mike Gondek , I use the Appearance Panel all dayyyy every day it's my bread and butter , i really like the color panel too , just on top of it ( I got "like photoshop" workspace set up )
thank you a bizillion very much !
Nov 26, 2014 Nov 26, 2014
If you have imported the vector from another document or SVG or PDF file, Control+J / Command+J will join the loose ends and help you out on most cases
Mar 17, 2015 Mar 17, 2015
This worked for me. Thanks fernandolins!
Apr 28, 2015 Apr 28, 2015
Thanks fernandolins86- your comment was perfect.
Thanks fernandolins! Hit the bulleye
Nov 26, 2019 Nov 26, 2019
You're a star, thank you!
May 27, 2021 May 27, 2021
Yes! This is it. This is the one! Thank you Fernando!
Feb 11, 2016 Feb 11, 2016
The "correct answer" doesn't work for me. I am working with a single, ungrouped object. Expanding appearance does nothing; aligning stroke to either inside or outside is greyed out. Period.
Then please create your own thread, because your problem is different.
Post a screenshot.
Mar 09, 2018 Mar 09, 2018
expand the shape then expand appearance, then try.
Worked for me.
Dec 27, 2020 Dec 27, 2020
Thank you but sadly not working. I ungrouped and even checked for open paths but nada. The options still don't appear.
Yo mean you have tried since 2018?
Can you perhaps show something?
Your problem path and the layers and the appearance panel (path needs to be selected)
Dec 30, 2020 Dec 30, 2020
Thanks for the reply. Looks like rebooting Illustrator did the trick... go figure. ~Cheers!
Participant ,
Apr 22, 2021 Apr 22, 2021
This glitch has just caused me to lose 5 hours of work after drawing a complicated floorplan and then finding out the client wants EXACT dimensions based on inside stroke measurement -  and this after cutting up the all the open paths for door openings. No way to re-align the stroke. Darn.
