hello,
My Flashbuilder is using AIR 17 as is visible in AIR aps.
However, my Adobe flex mobile app won't let me update a certain line in the .xml
I want to change:
<?xml version="1.0" encoding="utf-8" standalone="no"?>
<application xmlns="http://ns.adobe.com/air/application/3.1">
to
<application xmlns="http://ns.adobe.com/air/application/17">
Yet when I try and debug, I get a popup window that says:
Process terminated without establishing connection to debugger.
invalid application descriptor: Unknown namespace: http://ns.adobe.com/air/application/17
Launch command details: "C:\Program Files\Adobe\Adobe Flash Builder 4.7 (64 Bit)\sdks\4.6.0\bin\adl.exe" -runtime "C:\Program Files\Adobe\Adobe Flash Builder 4.7 (64 Bit)\sdks\4.6.0\runtimes\air\win" -profile mobileDevice -screensize 480x762:480x800 -XscreenDPI 252 -XversionPlatform AND "C:\Users\l\Adobe Flash Builder 4.7\CSemt\bin-debug\CSemt-app.xml" "C:\Users\l\Adobe Flash Builder 4.7\CSemt\bin-debug"
any help?
Back in the day, you had to overlay the Flex and AIR SDks to make it work. It may still be the case.
i've since switched to pure AS3 projects since I didn't use any Flex components, so I don't follow this workflow anymore, I do this instead: Update the AIR SDK for ActionScript Projects | Flash Builder 4.7
I remember following these instructions back when I was still overlaying the SDKs, maybe they'll help you:
Overlay AIR SDK on Flex SDK | Flash Builder
Obviously back up your existing SDK directory first....
Good luck!
Sounds as though you do not have either Apache Flex compiled with AIR 17 installed and set as the compiler: Project Properties > Flex Compiler
I'd recommend grabbing a fresh version of the SDK and AIR 17 via Apache FlexĀ® - SDK Installer
Hello guys,
I do have AIR 17 and Flex SDK 4.6. I'm up to date. And my project works fine in emulator mode, but not when downloaded in Android.
I think it could be this line:
Should probably be:
<application xmlns="http://ns.adobe.com/air/application/17.0.0.124">
Yet when I try and run it, I get a popup box error.
Any help?
If the AIR version is wrong it shouldn't even compile.
For AIR 17, try:
I tried that too.
Here is my entire project if you want to have a look:
I'm going to strip my project down to bare minimum tomorrow likely. No one likes looking through a lot of code when the problem isn't reduced to the bare minimum.
Does <application xmlns="http://ns.adobe.com/air/application/17.0"> work?
If no - are you sure the AIR 17 SDK is configured correctly in the project?
