Locked
4
Error! Check Activation. What do I do? [2015]
Apr 29, 2015 Apr 29, 2015
Hi, I have installed ADE v3 with Firefox. I have authorized my computer and my e-reader. When I try to load books, I get "Error! Check Activation." Anyone else have same problem?
Thanks.
Kobo editions
44.2K
correct answers 2 Correct answers
Adobe Employee , Apr 29, 2015 Apr 29, 2015
For this problem, you need to de-authorize and Authorize ADE again
Mac OS
  1. Open Adobe Digital Editions.
  2. Press Command+Shift+D to deauthorize Adobe Digital Editions.
  3. Select Erase Authorization.
  4. Click OK and quit Adobe Digital Editions.
  5. Open Adobe Digital Editions and reauthorize. [Help->Authorize Computer]
Windows:
  2. Press Control+Shift+D to deauthorize Adobe Digital Editions.
Community Beginner , May 01, 2015 May 01, 2015
Hi, the link you sent me to says that either my clock, date and/or time zone on my computer are incorrect. They were all fine. So I closed down ADE, deleted the books from my harddrive and downloaded them again from the library. I was able to open then in ADE and transfer them to my e-reader. Thank you!
Adobe Employee ,
Mac OS
Windows:
Hope this works !!
Apr 30, 2015 Apr 30, 2015
Thank you! Well, it worked in that it got rid of that error msg but now I have another one!
"Error getting license. License Server Communication Problem: E_ADEPT_REQUEST_EXPIRED."
What should I do for this one?
Thanks.
Adobe Employee ,
Please refer to URL:
Error: E_ADEPT_REQUEST_EXPIRED | Digital Editions
Hope this helps !!
Jun 16, 2023 Jun 16, 2023
Thanks, I had the same problem and I solved it with your guidance. I hate Adobe. Really.
Feb 22, 2021 Feb 22, 2021
G'day,  Simply reload the *acsm files because their date has expired if you waited more thsan a full day to install them... i.e. re-download the files you want to install in ADE ... CIAO
I have the "Error!  Check Activation." message as well, however when I try to deactivate, it says, "Unable to erase activation.  Please try again after some time."  I have tried at various times for two days.  This is on a laptop running Windows 8.1.  I tried removing authorization from my old laptop (Windows 7) with the same activation account and had no problems.   I tried using V3.0, and had the same error.  I have the Overdrive software downloaded and can open the files with that, however when I try to open the same ebook file on the other laptop, it will not open them and gives and ID error.  Any ideas?
Adobe Employee ,
If due to some reason, you are unable to deauthorize ADE, follow the below steps:
Windows:
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key:
HKEY_CURRENT_USER\Software\Adobe\Adept
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Your authorization will be deleted.
ADE will be deauthorized now.
Now Authorize ADE again.
Hope this works !!
Below Adept in the file tree, there is also Device and Activation (see attached screenshot).  I assume these have to do with my CS5 Creative Suite software.  Should I still delete the whole Adept file?
Adobe Employee ,
May 03, 2015 May 03, 2015
Try deleting "Activation" key first.
1. Delete the activation key
2. Launch ADE
3. Authorize ADE
Dec 25, 2020 Dec 25, 2020
Thanks. Had this issue on version 4.5. So annoying you have to go digging in registry to fix this.
Mar 30, 2021 Mar 30, 2021
Hi!
I have already delete Adept key file but it's still no option at the program to insert new authorization at my computer. Do I miss any step?
Dec 08, 2021 Dec 08, 2021
THANK. YOU!
Jan 06, 2022 Jan 06, 2022
You don't need to delete all Adept key.
You just need to go at Adept > Activation > 0000 > 0005, double-click in "value" and delete the e-mail address. Then open ADE again and proceed with deauthorization and reauthorizatoin. Worked here.
Feb 24, 2022 Feb 24, 2022
I had to delete all the user files from the folders 0001 to 0005 tobe able to desauthorize and authorize adobe.
Dec 29, 2023 Dec 29, 2023
Thanks for that - this procedure actually worked. This is the first time I've used ADR!  :).  I survived all the software transitions into the new millenium on New Years Day 2000, and here we are, on the cusp of 2024!
Nov 27, 2019 Nov 27, 2019
Thank you it works !!!
Oct 16, 2020 Oct 16, 2020
Thank you, shreya! You saved my day.
Mar 21, 2022 Mar 21, 2022
Thank you so much!  This solution worked for me as well.
Aug 01, 2023 Aug 01, 2023
I try it but I am unable to erase the authorisation.  It looks like it doesn't recognized my password. How I can do it?
Feb 25, 2021 Feb 25, 2021
bonjour, concernant adobe digital edition, une question, svp :
-  j'ai chez mon libraire, des livres .epub, et des livres .acsm
mon problème est avec les livres pour lesquels on ne me donne que un lien .acsm
-  les .acsm doivent-ils être lus toujours en ligne sur web actif, ou peut-on les télécharger sur un appareil (tablette, ordi ou tel portable par exemple), pour les lire hors connexion, ce qui est plus confortable si la connexion est mauvaise ?
merci d'avance
hi!
No, it has nothing to do with the internet or being online. When you download an acsm file, it will open in ADE and convert it to an epub, then connect your ereader, and put the book on there. You never need internet to read a book you have downloaded.
Feb 26, 2021 Feb 26, 2021
thank you very much Hi !!
