XMLTransform won't transform
Contributor ,
Nov 15, 2007 Nov 15, 2007
Ebay API sends back an XML response that starts like this:
<FindPopularItemsResponse xmlns="urn:ebay:apis:eBLBaseComponents">
When I do an XMLTransform on it, nothing shows until I remove the xmlns="... portion.
Anybody have a way to do this on the fly or someway of getting XMLTransform to work with that bit still in there?
Advanced techniques
336
Nov 30, 2007 Nov 30, 2007
1) create an XSL file called removeNamespacesAndPrefixes.xsl with the following code:
<?xml version="1.0" encoding="utf-8"?>
<xsl:stylesheet version="1.0" xmlns:xsl=" http://www.w3.org/1999/XSL/Transform">
<xsl:output method="xml" indent="no"/>
<xsl:template match="/|comment()|processing-instruction()">
<xsl:copy>
<!-- go process children (applies to root node only) -->
<xsl:apply-templates/>
</xsl:copy>
</xsl:template>
<xsl:template match="*">
<xsl:element name="{local-name()}">
<!-- go process attributes and children -->
<xsl:apply-templates select="@*|node()"/>
</xsl:element>
</xsl:template>
<xsl:template match="@*">
<xsl:attribute name="{local-name()}">
<xsl:value-of select="."/>
</xsl:attribute>
</xsl:template>
</xsl:stylesheet>
2) create a CFM template with the following:
<cffile action="read" file="#ExpandPath('.')#/file_with_node_namespaces_and_prefixes.xml" variable="XMLDoc">
<cfset transformedXML = XmlTransform(XMLDoc, "removeNamespacesAndPrefixes.xsl") />
<cfoutput>
<xmp>
#transformedXML#
</xmp>
</cfoutput>
Contributor ,
Dec 03, 2007 Dec 03, 2007
Thanx. Works like a champ. Now am I to assume that where you say to process children etc I should put the code I already have in there?
One other thing is killing me. I am rec'g this :
<TimeLeft>P1DT2H47S</TimeLeft>
I am trying to use :
<xsl:value-of select="minutes-from-duration(TimeLeft)" />
But I get "could not find function" error.
Is this not implemented fully or am I doing that wrong?
Documentation
