hi!
i am trying to retrieve data from microsoft crm, to do this i
need to use
webservices. i can correctly connect but then i try to use
the 'retrieve'
function and it complains about a parameter.
it seems to me cf wants to construct an abstract java class,
which ofcourse
fails. constructing the
"com.microsoft.schemas.crm._2006.Query.ColumnSet"
class via create object fails (the class i can use) because
it can not be
found.
anyone had this error before or has some pointers about how
to solve it?
alwin
--[ the error ]--
Error converting CFML arguments to Java classes for web
service invocation.
Unable to create web service argument class
com.microsoft.schemas.crm._2006.Query.ColumnSetBase. Error:
java.lang.InstantiationException. Often this is because the
web service
defines an abstract complexType as an input to an operation.
You must create
an actual instance of this type in Java. The error occurred
in
D:\www\cs.alwin\crm\webserviceTest\account.cfm: line 12
10 : username="-"
11 : password="-"
12 : returnVariable = "returnVar"
argumentcollection="#arguments#">
13 : </cfinvoke>
14 : <cfoutput>#returnVar#</cfoutput>
--[the code]--
<cfset arguments = structnew() />
<cfset arguments["entityName"] = "Account" />
<cfset arguments["id"] =
"3DB1F426-316F-DB11-8277-003048528AA5" />
<cfset arguments["columnSet"] = structnew() />
<cfset arguments["columnSet"].attributes = arraynew(1)
<cfset arguments["columnSet"].attributes[1] = "accountid"
<cfinvoke
webservice = "
http://myhost/mscrmservices/2006/CrmService.asmx?wsdl"
method="Retrieve"
username="-"
password="-"
</cfinvoke>
