Word 2003 & 2007
Guest
May 05, 2015 May 05, 2015
I have both versions 2003 & 2007 installed. Word2003 is my primary installation. But RH shall use Word2007. Just setting the default application and/or "Open With" does not help! How to solve this?
Remark: "Repair 2007" is *NOT* what I want to do, as then Word2007 opens all .DOC files per default!
291
Participant ,
Your question is somewhat difficult to interpret. You might want to rephrase it.
For RoboHelp 11 (and I believe 10), the supported versions of MSWord are Word2013 and Word2010.
Guest
Then we cannot use RH.
Nevertheless, the question is rather targetting the way how RH is opening Word. My setup works perfect in explorer - i.e. double clicking a .DOC opens Word2003 and double clicking a .DOCX opens Word2007 (of course, Word needs to be always closed before). But RH does not care about what is configured for double clicking or what is configured as "default application".
May 12, 2015 May 12, 2015
I think you will find that Rh uses whichever version of Word was last run. Try that.
@petergrainge
Guest
May 13, 2015 May 13, 2015
No definitively not. It always launches Word2003 (after a Word2003 repair) - no matter if Word2007 was the last one started. Word2007 is only used, after a Word2007 repair. And it does not matter what was assigned as default application (for double click in explorer)
May 18, 2015 May 18, 2015
I'm confused by your reply. After a Word 2003 repair, it will open Word 2003 by default. If you then open Word 2007 the Word 2007 repair will run and then that will be the default. Forget about what is assigned as the default.
You have to open the required version and if that is not the default Word will run the repair for that version, then use Rh.
@petergrainge
Guest
Tthis is not what I want.
I need Word2003 as "default" application and RH has to use Word2007.
i.e. when I double click a .DOC then word2003 shall open and a double click on a .DOCX shall open Word2007 - without any "repair" run. This works perfect since many Years.
Why is there no way to tell RH to use Word2007 in this setup?
May 19, 2015 May 19, 2015
Sorry it may not be what you want but it is the way it is. I agree it would be much easier if you could tell Rh to use a specific version but that is something only Adobe can fix.
Please follow this link and file a feature request.
http://www.Adobe.com/cfusion/mmform/index.cfm?name=wishform&product=38
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
