Deleting a record and the uploaded file problem
Contributor ,
Dec 04, 2007 Dec 04, 2007
Hello, I need to set up a delete function for a Database, and am trying to set it up so that the file that was uploaded to the server and is listed in the DB table, gets deleted with it. How would I write this out? here is what I have so far:
<cfquery name="DeleteRecord" dataSource="#sitedatasource#" maxRows=1>
DELETE
FROM feature
WHERE feature.ID = #Form.ID#
</cfquery>
<cffile action="delete" destination="c:/website/img/feature" file="#feature.MYFile#">
<cflocation url="feature_RecordView.cfm">
This doesn't seem to work, what am I doing wrong here? How would I write it out to make this feature work properly?
Phoenix
Advanced techniques
587
1) check the cfml reference for cffile action="delete" - youve got it wrong.
2) a presume the name of the file to delete IS coming from somewhere...
not the DELETE query... some query apparently named "features"... i
wonder where it is... ;)
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
Mentor ,
Which process doesn't seem to be working? The database deletion, the file deletion, or both?
Phil
Contributor ,
The file deletion isn't working.
Did I script it wrong?
Guest
Just a little tip... if possible use a yes/no or bit field type and flag it for active/inactive instead of actually deleting. Once it's gone, it's gone. I've had a few cases where actually saving the record and just 'deactivating' it was a better choice.
Check the CF log files for your error, you may not have access to delete on your web server.
You should also look into using query param in your WHERE clause. It's safer.
WHERE feature.id = <cfqueryparam cfsqltype="cf_sql_integer" value="#form.id#">
Contributor ,
this is my error:
Error Diagnostic Information
An error occurred while evaluating the expression:
"#feature.MYFile#"
Error near line 153, column 78.
Error resolving parameter FEATURE.MYFILE
ColdFusion was unable to determine the value of the parameter. This problem is very likely due to the fact that either:
You have misspelled the parameter name, or
You have not specified a QUERY attribute for a CFOUTPUT, CFMAIL, or CFTABLE tag.
The error occurred while processing an element with a general identifier of (CFFILE), occupying document position (153:2) to (153:94) in the template file c:\websites\x9vdzd\admin\Action.cfm.
Here is the code I am using, I changed it from your advice:
DELETE
FROM feature
WHERE feature.id = <cfqueryparam cfsqltype="cf_sql_char" value="#form.id#">
</cfquery>
<cffile action="delete" destination="c:/websites/x9vdzd/img/feature" file="#feature.MYFile#">
Any suggestions?
Contributor ,
would this be how the delete function is supposed to be?
<cfquery name="deleteFile" datasource="#sitedatasource#" username="#siteUserID#" password="#sitePassword#">
select feature.title, feature.Body, feature.MYFile
FROM feature
</cfquery>
DELETE
FROM feature
</cfquery>
or is this still wrong?
Phoenix
Mentor ,
How about using #deleteFile.MYFile# instead of #feature.MYFile#? Your variable requires the query name, not the table name.
Also, this query is going to return all of the rows from the feature table. Don't you think that you should include a WHERE clause to restrict what your query is returning?
FROM feature
</cfquery>
Phil
Contributor ,
if I use #deleteFile.MYFile# use a where statement like this
then use it in the cffile delete like this?
SELECT feature.title, feature.Body, feature.MYFile
FROM feature
WHERE WHERE feature.id = <cfqueryparam cfsqltype="cf_sql_char" value="#form.id#">
</cfquery>
DELETE
FROM feature
</cfquery>
<cffile action="delete" destination="c:/websites/x9vdzd/img/feature" file="#deleteFile.MYFile#">
Is this what you mean?
Mentor ,
Something like this....
FROM feature
</cfquery>
DELETE
FROM feature
</cfquery>
Guest
Just a note for the cfqueryparam. The cfsqltype="cf_sql_char" is if your field is a character type. If it's numeric then change this to <cfqueryparam cfsqltype="numeric" value="#form.id#">
Documentation
