How do I change the formatting of the default numbered list?
Participant ,
May 06, 2015 May 06, 2015
I've started a new RH 10 project and whenever I convert a paragraph into a numbered list by clicking the numbering button on the toolbar, the font changes to Arial. I need it to match my Normal style.
In all other RH projects if I click the numbering button, it creates the list but doesn't change the rest of the formatting. What's happening?
I've looked in the help but it tells me I need to define a new style etc etc. I've never done this before so am rather confused.
Is there a way of changing the formatting of a numbered list to match my Normal style so I can just click the toolbar button to convert a paragraph to a list?
371
Community Expert , May 06, 2015 May 06, 2015
It's probably because the body tag is set to Arial.
Normal is equivalent to a p tag, whereas lists are ul/ol/li tags and will inherit the font from body unless otherwise configured.
So you have a couple of options for editing the stylesheet in the RH editor (double-click on the stylesheet):
  1. You could change Other > Lists to your required font.
  2. You could change Other > Background + Text (BODY) to your required font. With this option, all your text should use this font, unless you define a different f
Contributor ,
Can you copy the .css from a "working" project and paste that into the appropriate folder of your new project?  (Maybe rename the existing .css so that you still have it, just in case.)
Participant ,
Thanks yes I could do - and might have to. I just wanted to understand how it's working.
If the behaviour I'm seeing is not usual then I'll put it down to a glitch. But I thought it might be something I need to learn my way around.
  2. You could change Other > Background + Text (BODY) to your required font. With this option, all your text should use this font, unless you define a different font for a specific style (e.g. for headings).
If you change Background + Text (BODY), you might like to edit your stylesheet in a text editor and remove the font-family entry for the p tag, but this depends on how comfortable you are with css.
Participant ,
May 07, 2015 May 07, 2015
Amebr, you are right - that has completely solved it.
Thank you SO much.
Participant ,
Jan 26, 2023 Jan 26, 2023
I know this is a long shot, but I am using RH 2020 and have the same issue. My text (body) is Calibri, but if I use the toolbar Numbered List button, the numbers display in Times New Roman or something like that (not even Arial, which seems weird to me). How do I make the numbers in the numbered list always display as Calibri?
Participant ,
I changed the properties of the Decimal style to get what I needed. Wish I could delete my question. 🙂
@bronxguys02 It will help someone in the future so it's good to leave it.
________________________________________________________
My site www.grainge.org includes many free Authoring and RoboHelp resources that may be of help.
Participant ,
And I am taking advantage of your Lists and Autonumbering information on your site. Thank you!
RoboHelp Documentation
Download Adobe RoboHelp
