Running ColdFusion 11 Update 4/5 on JDK 1.7
Guest
May 07, 2015 May 07, 2015
Hello, we're trying to debug problem we have with custom jar files that keep hanging our ColdFusion 11 instances with nothing being logged anywhere. One of the troubleshooting steps we want to do is to switch our new ColdFusion 11 Update 5 setup to run on JDK 1.7 instead of 1.8, because we know these jar files run just fine on our ColdFusion 9 JDK 1.7 platform. So, we repointed the instance we want to run in JDK 1.7 to correct JDK directory and tried to start the instance but the service will not start. We looked at the log file and Server Event Viewer shows this error: "... service terminated with the following-specific error: The system cannot find the file specified". The ColdFusion-our file doesn't have anything in it for that error (I don't think ColdFusion even gets to that point). The coldfusion-error.log file doesn't have anything specific either. Can someone help us debug this? Is there a way to increase the debug level so that we can get more info in ColdFusion log files? Thank you
May 06, 2015 2:46:57 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: D:\CF11\INSTANCE11\lib;D:\CF11\INSTANCE11\jintegra\bin;D:\CF11\INSTANCE11\jintegra\bin\international;D:\CF11\INSTANCE11\lib\oosdk\classes\win
May 06, 2015 2:46:59 PM org.apache.coyote.AbstractProtocol init
INFO: Initializing ProtocolHandler ["http-bio-8611"]
INFO: Initializing ProtocolHandler ["ajp-bio-8011"]
May 06, 2015 2:46:59 PM org.apache.catalina.core.StandardService startInternal
INFO: Starting service Catalina
May 06, 2015 2:46:59 PM org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.54
May 06, 2015 2:47:08 PM org.apache.catalina.core.ApplicationContext log
INFO: ColdFusionStartUpServlet: ColdFusion: Starting application services
INFO: ColdFusionStartUpServlet: ColdFusion: VM version = 25.45-b02
May 06, 2015 2:47:33 PM org.eclipse.jetty.util.log.JavaUtilLog info
INFO: jetty-9.0.7.v20131107
INFO: Started o.e.j.s.ServletContextHandler@5786f47c{/,null,AVAILABLE}
INFO: Started ServerConnector@44a694df{HTTP/1.1}{0.0.0.0:55065}
May 06, 2015 2:47:36 PM org.apache.catalina.core.ApplicationContext log
INFO: CFMxmlServlet: Macromedia Flex Build: 87315.134646
May 06, 2015 2:47:58 PM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor D:\CF11\INSTANCE11\runtime\conf\Catalina\localhost\cfscripts-obfs.xml
May 06, 2015 2:47:58 PM org.apache.catalina.startup.SetContextPropertiesRule begin
WARNING: [SetContextPropertiesRule]{Context} Setting property 'debug' to '0' did not find a matching property.
INFO: Deployment of configuration descriptor D:\CF11\INSTANCE11\runtime\conf\Catalina\localhost\cfscripts-obfs.xml has finished in 859 ms
May 06, 2015 2:47:58 PM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8611"]
INFO: Starting ProtocolHandler ["ajp-bio-8011"]
May 06, 2015 2:47:58 PM com.adobe.coldfusion.launcher.Launcher run
INFO: Server startup in 64058 ms
404
Deleted User
Funny how sometimes things work. As soon as I posted this question, I thought of starting ColdFusion in a console and right away I saw the error there:
Unrecognized VM option 'MaxMetaspaceSize=256
Could not create the Java virtual machine.
I guess I forgot I added new memory option specific to JDK 8 few weeks back. I posted it back here for reference in case someone runs into similar issue.
Guest
Documentation
