There does seem to be a problem here. I imported a topic with
snippets in it. After the import, there is a blank line where the
snippet should be. You could either delete that or you can go into
the code and delete the snippet reference. Of course what should be
happening is that the import routine should be either importing the
snippet or warning that some action is needed. The danger of
automatically importing the snippet is that in project two you
might have a snippet with the same name but different content.
I too had an abend at one point but could not repeat it.
If you import the snippet first and then the topic, then it
does seem to work.
I will notify Adobe of this issue.
