We are testing Presenter 10 to roll out to replace Presenter 7.0.6.
I published a test course with 1 slide and two questions as SCORM 1.2.
When a run the content in IE11, there are serious display issues (question option text doesn't show, double radio buttons, no labels on submit button). This behavior is the same whether I publish as SWF or as both. I am able to click through and complete the course.
In IE8, I get JavaScript errors.
Publishing as SWF gets me the following errors:
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; .NET4.0C; .NET4.0E; MS-RTC LM 8; InfoPath.3)
Timestamp: Mon, 11 May 2015 20:53:59 UTC
Message: Expected identifier, string or number
Line: 101
Char: 5
Code: 0
URI:<REDACTED>/data/html/presenter.libs.js
After I close this error, my LMS just churns trying to load SCORM.htm.
Publishing as Both gets me the following errors:
Timestamp: Mon, 11 May 2015 21:07:30 UTC
Line: 1
Char: 467
Code: 0
URI: <REDACTED>/data/html/Project.js
Line: 101
Char: 5
Code: 0
After this error I get an object expected error on the "loadPrContent()" function in the SCORM_utilities.js.
After that it's just a blank page.
Help?
That was one of the earlier things that I tried. Our LMS (sumtotal) opens SCORM content in a frameset, and I suspect that's why the compatibility mode meta tag isn't working the way I expect it to.
Hi There,
Presenter 10 is not tested with IE 8. It only supports IE 9 or later. Let us know the issue you are facing with IE 11 and Presenter 10. DId you also try the output in cloud,scorm as well on IE 11?
Mayank
