I'm having problems with quizzes in Adobe Presenter 10
Dec 02, 2014 Dec 02, 2014
I'm having problems with quizzes in Adobe Presenter 10, upon publishing, the text just disappears and the buttons look weird, also the text on submit buttons doesn't show?
Presenter
723
Dec 13, 2014 Dec 13, 2014
I have the same issue..id you find the solution for this?
Apr 20, 2015 Apr 20, 2015
Yesterday everything was OK. But today I have the same problem inside of all my presentations with questions. Will be glad if someone can explain it….
Adobe Employee ,
Apr 21, 2015 Apr 21, 2015
Hello,
Welcome to Adobe Forums.
Shared Files - Acrobat.com
I am sending you a .dll file on your email . Please follow the steps given below and see if it resolves the issue:-
  • Please download the zip file attached to the email and extract it.
  • Please check the version of Presenter installed on your machine
  • For 32bit: Please copy the PptImgExporter.dll from 32 bit folder and paste it under “C:\Program Files (x86)\Adobe\Adobe Presenter 10.0”.
  • For 64bit: Please copy the PptImgExporter.dll from 64 bit folder and paste it under “C:\Program Files\Adobe\Adobe Presenter 10.0”.
  • Please try to publish the project now.
Please let me know if you face any issue.
Rajeev.
May 04, 2015 May 04, 2015
We had the same issue and this fix worked for us.  Thank you.
May 12, 2015 May 12, 2015
I am having the same issue, i think.  Due to firewall restrictions at my company I am unable to access the Acrobat.com shared file link.  Is there any way, Rajeev, for me to send you a private message with my e-mail address?
Adobe Employee ,
You may send me your details at my email address rasaini@adobe.com.
Please let me know if that doesn't work.
Rajeev.
Rajeev, I was able to find a workaround to get the file from that location, and now published conent displays fine in IE11, but I still have a multitude of other issues.  Javascript issues in IE8, Blank screen in IE11 when running AICC from our Connect Server.
Adobe Employee ,
Is it happen with a specific project or any project which you create with quiz.
Did you try to create a sample AICC course and upload it to connect server.
What kind of errors you are getting in IE8. Which output you generating in Adobe Presenter ?
Rajeev.
I created a dummy test project with one slide and two quiz questions.  I uploaded to a Connect 9 server for AICC testing.
______________________________________________________________
Publishing as SCORM, running in IE8 gets the following results:
Publishing as SWF gets me the following errors:
          Webpage error details
          User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; .NET4.0C; .NET4.0E; MS-RTC LM 8; InfoPath.3)
          Timestamp: Mon, 11 May 2015 20:53:59 UTC
          Message: Expected identifier, string or number
          Line: 101
          Char: 5
          Code: 0
          URI:<REDACTED>/data/html/presenter.libs.js
After I close this error, my LMS just churns trying to load SCORM.htm.
Publishing as Both gets me the following errors:
Timestamp: Mon, 11 May 2015 21:07:30 UTC
Line: 1
Char: 467
Code: 0
URI: <REDACTED>/data/html/Project.js
          Line: 101
          Char: 5
          Code: 0
After this error I get an object expected error on the "loadPrContent()" function in the SCORM_utilities.js.
After that it's just a blank page.
___________________________________________________________________________________________________
Publishing AICC to a Connect 9 server, publish as BOTH, Accessing in IE8 gets the following results:
               Timestamp: Tue, 12 May 2015 19:19:45 UTC
               Line: 1
               Char: 394
               Code: 0
               URI:<redacted>/output/data/html/Project.js
               Timestamp: Tue, 12 May 2015 19:21:49 UTC
               Line: 101
               Char: 5
               Code: 0
               URI: <redacted>/output/data/html/presenter.libs.js
               Timestamp: Tue, 12 May 2015 19:23:00 UTC
               Message: Syntax error
               Line: 1
               Char: 1
               Code: 0
               URI: <redacted>/output/data/resources/ha/wr_/OpenAjaxManagedHub-all.js
After closing the final error message, I get a blank screen.
Adobe Employee ,
Please check the output on any other browser since there might be compatibility issue with this version of browser. Internet Explorer 8 is not a supported browser for Adobe Presenter 10 output.
http://www.adobe.com/uk/products/presenter/tech-specs.html
Rajeev.
Help resources
