Hi Tom J.
If you are intent on mouseover effects for the button, you
are probably in for a fun ride coding some special solution.
Personally, if I want an image for these, I take the
following approach:
Insert an image.
Insert the RelatedTopics control and choose "Hidden, for
scripts"
Note the actual name of the control. Often it is simply
RelatedTopics. But depending on how it was inserted, may be
object1. Just hover the control in your WYSIWYG editor and the name
should pop up in a tooltip.
Select the image and make it a hyperlink. But in the
hyperlink properties, type
JavaScript:RelatedTopics.Click();. (and if the name differs
from RelatedTopics, use what you saw instead.
This method will make it so your user clicks the image and
the control activates.
Cheers... Rick
