Hi All,
I'am learning to use the fdk , wanted to know if its possible to get all the tags present in the active frame document can someone point me out to a function or a snippet to do this ? Lost in the sea of functions.Trying to generate the conversion table programatically.Any help is much much appreciated.Thanks in advance.
[Moved to Scripting forum by moderator]
Have a look over in the Scripting forum.
You can have a look at a utility shared at ExtendScript of the Week: “Change Styles – (Para/Char/Table)” « TechComm Central by Adobe
You will get the desired code snippet to get a list of all tags from here.
Anchal
FM Engineering
Thank you so much Anchal , I'll take a look at this
Apoorva, this is a reasonable task for an FDK client, but it is not for the beginner. You can get the first paragraph format with the following, where docId is a valid document F_ObjHandleT handle:
F_ObjHandleT pgfFmtId;
StringT pgfFmtName;
pgfFmtId = F_ApiGetId(FV_SessionId, docId, FP_FirstPgfFmtInDoc);
//then you can get the format name with:
pgfFmtName = F_ApiGetString(docId, pgfFmtId, FP_Name);
//then you can get the next format with:
pgfFmtName = F_ApiGetId(docId, pgfFmtId, FP_NextPgfFmtInDoc);
...but as I say, the full implementation of conversion table generation is a significant and complicated task. You really have to know a lot about a lot of FDK things.
I'll mention this... the GUI provides a function to do this already, StructureTools > Generate Conversion Table. Can you just use that? I think you should be able to invoke this programmatically as well, so maybe there is no need to reinvent the wheel here.
Russ
Hi Russ,
Thanks a ton for the reply, however I did see another discussion your answer has been very useful here also.
Re: FDK - apply Conversion Table to document
But all i need is a program structure i cant get started with this since i do not know where to begin or which sample to look at , perhaps something like the ones in the samples directory of fdk , can you help me with the structure ?
Apoorva,
Do you have Visual C++ installed? This is your first step. You'll need VC++ 2010 for the latest versions of FM and the FDK. You can get VC++ 2010 Express for free that will compile an FDK client. Then, maybe open some of the FDK samples and begin to experiment. There is a big learning curve here if you have never worked in a development environment before.
You might consider ExtendScript instead. It is much easier for the beginner and it can do quite a lot. Consider getting some samples and playing around:
FrameMaker ExtendScript Samples - West Street Consulting
Russ
Thanks Russ,
I have VS2010 and i executed a few samples of fdk .With extensscript is it possible to convert from fm to xml? This is a small snippet of code that i tried ,from the fdk programmers guide.But somehow not executing fully dont really know what the error is
inputDocId = F_ApiSimpleOpen((StringT)"D:/FrameTest/abc.fm", False);
ruleTblDocId=F_ApiSimpleOpen((StringT)"D:/FrameTest/new_conv.fm", False);
if (!inputDocId || !ruleTblDocId)
F_ApiAlert((StringT)"Couldn’t open.",FF_ALERT_CONTINUE_NOTE);
else
F_ApiCallClient("Structure Generator", "inputDocId");
F_ApiCallClient("Structure Generator", "ruleTblDocId");
F_ApiCallClient("Structure Generator", "D:/FrameTest/new_doc.fm"); // this line not working i suppose
F_ApiCallClient("Structure Generator", "StructureDoc");
