2 Replies Latest reply on May 16, 2015 5:34 AM by frederickyocum
    What strategy to use for error messages?
    frederickyocum Level 1
      I am in the process of finessing some small scripts I wrote and am wondering whether I can settle on what kind of functionality to build to pass error messages back to the user.
      There are numbers of places my scripts should bottle out of a process.
      • At the beginning if there is no document open or nothing is selected.
      • In the middle of functions when checking for a variable value or state that is necessary to proceed.
      While I could just use alert() this seems too rudimentary and not particularly branded.
      Another simple way to handle this would be to define a global variable and write an error message to it when encountering a problem point. Global variables would be available anywhere in the script. In the main function, at each transition point the global variable could be checked, and if the value is something other than null, the value passed to a function that would present the error message to user and terminate the script. This however relies on a global variable something which is frowned on.
      xbytor’s logging strategy described here, would be great for large scripts but seems like over kill for the kind of small scripts I am building.
      Suggestions appreciated.
        • 1. Re: What strategy to use for error messages?
          Marc Autret Level 5
          My two pennies on this topic.
          I'd make a clear distinction between messaging stuff, debugging tools and error management.
          1. Messaging: prompting warnings, alerts, etc. to the user when something is wrong regarding the context from which s/he runs the script, or similar issues. E.g. "nothing is selected", "no document available" etc. These are not errors in the strict sense (although true errors may require messaging too.) To me, messaging is just an interface issue. It answers the question, how and when should I notify something special to the user? This shouldn't be strongly coupled with error management, because in most cases the bug is the user, not the script. A good script is responsible for detecting usage or context-related failures and should not throw exceptions in such cases (IMHO).
          2. Debugging: this is obviously a very broad question, which involves as well testing strategies, code quality tools (JSLint etc.), assertions, logging. All this stuff is clearly intended for the developer. Having in your toolbox a good logging library that you just need to include whenever a project becomes serious is the best approach to me. Logging features are somehow “embedded” in the final script, but they remain silent as long as the log level is zero. On the dev side you use various levels (e.g. trace, warning, error, critical…) during the design, but I suggest logging be also activatable from the user side—based on some hidden switcher—because users are expert in detecting issues. Having a verbose log report of all what happened before your script made ID crash is the most precious thing in the world.
          3. Error management: this is the realm of “exceptions” and try-catching. That is, issues that shouldn't normally occur and would lead to runtime errors if they were not managed. ExtendScript provides exception handling and implements the basic Error types required by ECMA's specification. Note that error management is both connected to messaging (1) and debugging (2) but it seems to me very useful to consider it a separate domain. It answers the question, how, when and where do I manage actual errors? One side of error management is throwing custom exceptions. A good practice is to have some flag on your custom Error object so that you can identify that this was not a 'native' error. Exceptions should be thrown as close to where the error would have occurred (in order to recover the maximum amount of contextual data), but opinions are sharply divided about the place from where exceptions should be caught. A global try...catch embedding your whole script makes things very easy to manage, but there are less paranoid solutions. Either way, having a dedicated function (not only a “global variable”) for sending, storing, and receiving errors is, I think, the way to go.
          Marc
          • 2. Re: What strategy to use for error messages?
            Thanks Marc. You have clarifed what I should be exploring which is messaging. The scripts I am working on are relatively simple. There are numbers of places in scripts where a condition may not be met, sometimes this may  mean there is no point in going further, sometimes it means part of the script is not needed (No paragraphs in US English). Having a function for dealing with telling the user what is going on seems better than relying on various alert() messages sprinkled about the script.
