I'm getting download failed when trying to download Adobe Flash Player 32-bit/64-bit Plugin 17.0.0.188 and Adobe Flash Player 32-bit/64-bit ActiveX 17.0.0.188 to my SCUP server.
PublishItem: Successfully retrieved content for software update 'Adobe Flash Player 32-bit/64-bit ActiveX 17.0.0.188 (UpdateId:'dc3d262e-f15f-40b2-8436-ff43fb0cb0dd' Vendor:'Adobe Systems, Inc.' Product:'Adobe Flash Player')' to local file: C:\Users\<username>\AppData\Local\Temp\\gsd3kesd.fki\install_flash_player_17_active_x.msi | Updates Publisher | 5/12/2015 12:49:48 PM | 12 (0x000C) |
PublishItem: --- Digest verification failed on content for software update 'Adobe Flash Player 32-bit/64-bit ActiveX 17.0.0.188 (UpdateId:'dc3d262e-f15f-40b2-8436-ff43fb0cb0dd' Vendor:'Adobe Systems, Inc.' Product:'Adobe Flash Player')'. | Updates Publisher | 5/12/2015 12:49:48 PM | 12 (0x000C) |
PublishItem: --- Publish of software update 'Adobe Flash Player 32-bit/64-bit ActiveX 17.0.0.188 (UpdateId:'dc3d262e-f15f-40b2-8436-ff43fb0cb0dd' Vendor:'Adobe Systems, Inc.' Product:'Adobe Flash Player')' has FAILED. | Updates Publisher | 5/12/2015 12:49:48 PM | 12 (0x000C) |
I just tried going back and loading with IE as I had done originally.
Except this time IT WORKED!!!
You guys must have changed something.
Thank you for all your help!
Hi MNovitsch,
Please don't post the same issue multiple times. It's unnecessary and creates confusion when the same topic/thread is forked. I've deleted your other, duplicate post.
I'm looking into this issue and will post back shortly.
Maria
I'm sorry didn't realize I had created multiple posts. Thank you for looking into it.
Hi MNovitsch,
I downloaded the SCUP catalog and the MSI installer and verified the digest value of the MSI installerer matches what's in the SCUP catalog (the output you posted indicates the digest verification failed). It's possible when you downloaded the MSI installer that the previous version downloaded. Sometimes it can take a bit of time for the new version to propagate throughout the system and I have seen other posts on the forum that some users were still getting the previous MSI version as recent as 30-40 minutes ago. Please double-check that the MSI file downloaded is indeed the latest version (17.0.0.188), if not, please download the installers again. If you continue to get the previous version, instead of the new, you may need to clear your browser/server cache to download the latest version.
Maria
I'm also experiencing the same issue but for latest Flash Player Plugin update... and tried multiple times for 3 hours now...
How do I check the .msi file if it dissapears instantly from Temp folder? ON the other hand when I downloaded the file directly from https://download.macromedia.com/pub/flashplayer/current/licensing/win/install_flash_player_17_plugin... (as per Download URL in updates info) it is the previous update version (17.0.0.169)
What do you mean by server cache exactly?
EDIT:
I just deleted and re-added the update by importing proper software updates catalog but the issue persists
Mine was able to download this morning without any problems.
I am wondering if all Adobe file servers are updated with same Flash Player update version...
In one environment I can easily download the update manually, on another one (different network, domain, country whatever you can think of) I can only download older version. Checked web browser is trying to connect different servers in both cases when downloading file.
Hello all,
Thank you all for reporting that the new files still aren't updated in certain locales. I am looking into this and will post back shortly.
Maria
Hello,
We believe this issue is now resolved. Please try again. If you're still getting the previous version please provide the following:
Thank you.
Maria
¡Hola! Thanks, works fine now. I was able to import the current Acrobat-, Reader- and Flash Player Updates.
Hi Tom,
Thank you for confirming you're now getting the latest version. Much appreciated.
Maria
Portland, OR on Level 3/TW Telecom network. Still not downloading the correct MSI versions.
Still NOT working 17.0.0.188 on Windows 7 IE. Keeps downloading 169.
Did work for Firefox.
Located near Worcester Mass - if that helps.
Hi richards99422353,
Are you clearing browser cache on IE? If so, in Internet Options > Browsing History > Delete Browsing History is the 'Preserve Favorites website data' check-box selected or not?
By default this check-box is selected. When selected, IE may be preserving data from previous downloads and not actually downloading the new files especially since the URL is the same.
Maria
I did clear the browser cache (IE) and even restarted Windows.
Still has 169.
Preserve Favorites website data - NOT CHECKED
Does this link have the 17.0.0.188?
http://fpdownload.macromedia.com/pub/flashplayer/latest/help/install_flash_player_ax.exe
Its still NOT working for me.
I just get 169 for IE.
Any ideas - what to do?
You stated earlier you were getting 188 using Firefox. Are you using Firefox to download from this URL or IE? If IE, please try with Firefox.
Maria
I just tried using Firefox to download the IE ActiveX and still no luck.
I still have:
ActiveX version 17.0.0.169
NPAPI version 17.0.0.188
The link I used is:
Am I using the right link?
The link path includes "latest". Is "latest" set to the wrong rev?
Is there a specific 17.0.0.188 link to download from?
Great. Glad to hear it's downloading for you now.
Maria
