I have just updated to Lightroom 6 through creative cloud. Lightroom 5 used to work perfectly, if a little slowly, but 6 just keeps crashing when I try to browse or edit images. This morning it has crashed 30 times and I have only managed to edit 5 images from a recent wedding. I've disabled all plugins, but that didn't help, and have tried to boot in safe mode, again with no success. I am running a MacBook Pro, 2.53 GHz Core2 duo, 8GB RAM, NVIDIA GeForce 9400M 256 MB, Yosemite, 500GB SSD. I have tried to go back to LR5 but the updated catalogue won't work with it. Any ideas anyone?
Your original LR5 catalog is still there, so you could go back to that, and you'd only lose the work that you did on the 5 images.
But with LR6, try turning off the GPU option on the Lightroom>Preferences>Performance tab. Does that make a difference?
Thank you - it's working so far, but now very slow to render previews.
Similar issue. Lightroom 6 kept crashing only when I turned off GPU it is stable however very slow
I can't even turn off my graphics processor, as soon as I click to untick the box the whole program freezes. Any ideas anyone? Only bought this today to replace 5.7 and am severely disappointed.
To turn the Graphics Processor option off before starting Lightroom, read this link-
Turning off Lightroom’s GPU preferences even when crashing on startup. | Lightroom Blog
And-
Resetting the lightroom preferences file - updated - Lightroom Forums
Thanks very much
Did that work for you?
And are you still able to see pics in high res?
I'm using Windows. Looks like my issue was the GPU option. Followed instructions in wobertc's post to disable in the preferences file as it was crashing pretty much right after startup. My GPU is not very powerful, 1Gb DDr5 AMD Radeon 7800, but sounds like users are having issues with even more powerful cards. If you're on Windows go to C:\users\user\AppData\Roaming\Adobe\Lightroom\Preferences and edit the Lightroom 6 Preferences.agprefs in notepad or note++. Search for "useAutoBahn" and set to "false". If your issue is the same that should help.
Thanks for the trick. I tried to turn off the GPU option directly from the program itself and it keeps crashing. Changing the true to false from notepad works great!
This is the answer. I was in tears LR CC kept crashing and along the way created a temporary catalog after I fixed my catalog it continued. Luckily my hubby is a techie. He googled it and fixed it using the GPU preferences. What a pain. People shouldn't have to be this technical to get LR CC stable.
Yes, I even tried that GPU settings on and off. I even set up a second users account. I then put in my old Lightroom 4 disk, tested it . It played the videos to edit and created the slideshows without crashing. i even have Lightworks video editor on this and it played videos. Even before I did that, Lightroom CC 2105 crashed. But on Windows 10 only. Luckily, I can use Adobe Photoshop CC 2015 to edit videos without it crashing. But slide shows for me are easy to understand creating them in Lightroom cc 2015.I guess if I bought a new vehicle, I would expect;all of the vehicle together. i will call them this week. Thanks
When you say it was fixed using GPU preferences, what settings did you change? Just the GPU acceleration setting in LR or settings for the graphics card itself?
Are you concluding that your catalog has been corrupted in some way?
I am also having the same video functioning problems (LR will not operate with any video files; it hangs by just putting my cursor over the video file list in my LR library list). I had been running LR4 just fine. I upgraded to LR 6 a few months ago and at the same time upgraded to W10. Other problems caused me to revert to W7. Then I noticed the video files were no longer working.
I just installed LR 4.4 on another computer (W10) and copied to that computer an older backup catalog and the original video files. Video works fine on that computer.
I installed LR 4 into the same computer when I edited the videos in same computer as Lightroom CC 2015 with Wndows 10. I just turn off the GPU. My graphics card isn't or wasn't changed. Same graphics card.I just believe Adobe doesn't really know how to fix it. I won't call them about it, because it is too frustrating. I will keep it this way. You should be able to edit videos and slide shows in Photoshop . . I did one that way on the same computer that Lightroom CC 2015 wouldn't edit on.Just doesn't make sense to me. i guess that is better than being frustrated.2 other programs I tried were worse than Lightroom. so I will keep this LR.
Whenever I try to do this fix, it just crashes rather than unchecking the box. It's so screwed up. I can't get any of my business work done. I have clients waiting for pics and this newest update just crashes. Ugh.
Try the "Manually disable the graphics processor" section on Adobe Lightroom GPU Troubleshooting and FAQ
This was a huge help. Thanks
I'm running Windows 10 - The whole purpose of having a graphics card is to use it... I have the AMD ATI FirePro V Graphics card and lightroom keeps on crashing. Very hard to get any work done! If I turn off the graphics card then things slow down considerably. Please fix this ASAP!!
The GPU is the culprit. Of course Adbobe knows this. They chose to release defective software. Adobe owes it subscribers at least one months's subscription payment.
Like others Lightroom CC kept crashing on me whenever I'd try to click on the "develop" tab. Running Windows 10 with 12g of ram, I7 processor SDD. it's pretty fast. I checked the support post about the GPU and it turns out I'm the lucky guy with the one graphics card they don't support on Windows, AMD Radeon HD would have been nice to know this before signing up for the monthly subscription. Turn off GPU and it stopped crashing but it clearly runs more sluggish than the old Lightroom 5. Not great.
My Lightroom 4, work editing videos and slide show. , but not my Lightroom CC 2015. It won't do slide shows neither. I decided I won't do slide show or videos in CC 2015.
Turning off GPU did not help me. LR6 crashes everytime I click on a video.
Windows 10, LR 6, Premiere CS6, and so much more .... nothing but more headaches.
Wish I had never heard of Windows 10.
It worked for me thanks (NVIDIA® GeForce® GTX™ 950M)
I have a similar spec macbook pro running a 23" Cinema Display and if i leave GPU OFF - Lightroom works so perhaps our spec is too low ? Would be interested to know
Same here. Random crashes when editing. tagging, cropping... Never an issue the LR5
2007 MacBook Pro 3,1
Core 2 Duo 2.4 GHz
6Gb memory
512mb Samsung EVO 850 Pro SSD
Lightroom version: CC 2015 [1014445]
License: Creative Cloud
Operating system: Mac OS 10
Version: 10.10 [3]
Application architecture: x64
Logical processor count: 2
Processor speed: 2.4 GHz
Built-in memory: 6,144.0 MB
Real memory available to Lightroom: 6,144.0 MB
Real memory used by Lightroom: 276.2 MB (4.4%)
Virtual memory used by Lightroom: 878.3 MB
Memory cache size: 52.8 MB
Maximum thread count used by Camera Raw: 2
Camera Raw SIMD optimization: SSE2
Displays: 1) 1440x900
Graphics Processor Info:
NVIDIA GeForce 8600M GT OpenGL Engine
Check OpenGL support: Passed
Vendor: NVIDIA Corporation
Version: 3.3 NVIDIA-10.0.31 310.90.10.05b12
Renderer: NVIDIA GeForce 8600M GT OpenGL Engine
LanguageVersion: 3.30
