1 2 3 Previous Next 81 Replies Latest reply on Jan 23, 2018 3:34 PM by jojol71879057
    Terrible performance on iMac 5K
    Totallynotjan Level 1
      Hey Adobe Forum!
      I got my high end iMac 5K from Apple (4GHZ, M295X, 24gb Ram).
      I planned on primarily using the Adobe Creative Cloud and especially programs such as Lightroom, Photoshop, InDesign, Edge.
      With an exception for Photoshop all of the above mentioned programs run horribly.
      While browsing my catalogues in Lightroom it stutters and freezes. Edge runs as if it was running under 20fps, very laggy and stuttery.
      InDesign is also pretty slow while switching pages and scrolling in general.
      My questions: Is this normal for Hi-DPI screens? Is anyone else experiencing this?
        • 1. Re: Terrible performance on iMac 5K
          robgendreau Level 3
          I use the same setup (but 32GB RAM). I don't seem to have the same problems as you.
          I get some stepping and even a bit of tiling in the Develop module if I whip say the "contrast" slider back and forth in some applications. If I just enter a value, or just one-click somewhere else in the slider, it seems to be perfectly snappy. If I move a photo to my second 2560x1440 monitor, it seems less pronounced. Some applications and plugins are worse than others; MacPhun's pro applications like Tonality Pro seemed to do the best in making smooth transitions.
          All the copying, filtering, organizing stuff is very quick. I haven't had any issues with cropping images, although others have.
          I am wondering if some of this is Yosemite. Or maybe there are caches or something that is slowing stuff down. I doubt it's the machine since some get really fast results, see http://www.tony-hart.com/blog/essays/2014/10/imac-with-retina-5k/ for an example.
          • 2. Re: Terrible performance on iMac 5K
            This is indeed strange. I already did a clean install of Yosemite and Adobe CC, the problems stay. Even with a new catalogue of photos.
            My biggest problems are in the library view mode, I cant browse through my photos without heavy lag and wait times. Also, the cropping tool is very slow. Changing the values on brighteness etc does work 'okay' for me..
            • 3. Re: Terrible performance on iMac 5K
              dj_paige Level 10
              Some things to try:
              Optimize your Catalog
              Performance hints
              • 4. Re: Terrible performance on iMac 5K
                robgendreau Level 3
                That "performance hints" reads like an argument to try another product
                What size previews are you using? I'm using high quality, 2880 pixel previews.
                • 5. Re: Terrible performance on iMac 5K
                  I Already tried those tips - without success. Thanks though.
                  im also using 2880 high..
                  • 6. Re: Terrible performance on iMac 5K
                    Badly Drawn Boy Level 1
                    See this thread and this one. Unfortunately, until Adobe figures out a fix, the only solution is to reduce the LR window size to about 1/4 full screen. (Yes, this entirely defeats the purpose of a 5k iMac, but there it is.)
                    • 7. Re: Terrible performance on iMac 5K
                      smathia Level 2
                      Try reducing preview size to 1024 pixels and medium just to see if that relives the issue…..it did for me
                      • 8. Re: Terrible performance on iMac 5K
                        robgendreau Level 3
                        As a point of reference and in addition to my comments above, I tried other applications to see if I had similar stepping/stuttering issues in using for example the exposure slider.
                        I tried Capture One Express, Graphic Converter and Aperture. None exhibited the problems that LR has. Even LR's slideshows are choppy, and I assume it scales to fit, so it's not 1:1 in that instance. You might wanna try these other options if that stuttering bugs you.
                        I tried some plugins as well, specifically Tonality Pro from MacPhun since it runs as a stand alone application as well. Within LR, it was slow to respond to an exposure slider. But it did NOT have the same problem when I used it as a stand alone.
                        So, Adobe, what's up?
                        • 9. Re: Terrible performance on iMac 5K
                          I have similar performance Issues in Illustrator, InDesign and Acrobat X. Not only Lightroom.
                          • 10. Re: Terrible performance on iMac 5K
                            On the Optimizing Performance page linked to above, Adobe says this regarding preview size:
                            To make standard previews small, specify the appropriate the size and quality in the Catalog Settings dialog box:
                            • Choose Edit >  Catalog Settings (Windows) or Lightroom > Catalog Settings (Mac OS), and then select File Handling.
                              For Standard Preview Size, choose the amount that is closest to the longest edge of your screen resolution, but not shorter than it. For example, if your screen resolution is 1920 x 1200 pixels, choose Standard Preview Size > 2048 Pixels.
                              For Preview Quality, choose Low or Medium, which equates to the low- or mid-range of the quality scale for JPEG files.
                            Note: The larger the monitor you use (and the higher resolution), the more work Lightroom does to calculate previews and update pixels when you make adjustments. If you experience performance slowdowns with large monitors, try reducing resolution of the display using the Display Control Panel (Windows) or Displays System Preferences (Mac OS).
                            Seems to me what it's saying is "don't make previews larger than they have to be". But I don't understand how making previews smaller than they should be would increase performance? If anything, seems it would decrease it.
                            • 11. Re: Terrible performance on iMac 5K
                              For the record, the NIK plugins seem to have similar performance issue regardless of whether I open with Photoshop or use the standalone NIK editor.
                              • 12. Re: Terrible performance on iMac 5K
                                BCS Group Level 1
                                I was just about to order a 5K iMac but after reading this thread I think I'm going to go for a standard unit and upgrade the processor and RAM instead.
                                Earlier this year, I was doing all my editing on a Windows laptop and was considering upgrading to a Dell XPS laptop which boasts a display on par with the MBP retina. After lengthy research I decided against the XPS due to problems I read that owners were experiencing with Adobe applications displaying correctly on the ultra-high resolution display. To date, I am unaware that this issue has been resolved.
                                Shortly after this, I acquired a 2009 iMac 27" and have been a converted Mac user ever since. I'm so glad I've researched all that I have today because I could've wasted a lot of money and not had the gains in performance I am looking with upgrading to a new machine.
                                • 13. Re: Terrible performance on iMac 5K
                                  Steveatesh Level 2
                                  I don't know if this helps but I have the base retina iMac (ie i5 and R290 GPU) made up to 16 gig RAM.
                                  I'm currently trialling Lightroom and love it. I've experienced the occasional jerkiness when say using the graduated filter but nothing horrendous. This on full screen using RAW files.
                                  I also trialled Corels Aftershot Pro 2 which , unlike LR, makes full use of the GPU. Aftershot was instant in response with the same images - everything was smooth, no delays and no shuddering or jerks.
                                  That suggested to me that there is nothing fundamentally wrong with the riMac but the problem lies with LR. I much prefer LR as a program and am considering taking it via the CC, but I hope Adobe improve its use of GPU with version 6.
                                  • 14. Re: Terrible performance on iMac 5K
                                    BCS Group Level 1
                                    I run the usual Adobe CC photography apps along with Indesign, Illustrator and Bridge. I would be gutted if I invested £2k to discover it isn't a massive step up from my current setup. I'd pretty much made up my mind to go with the 5K i5 model and up the RAM like you have but now I'm not so sure.
                                    • 15. Re: Terrible performance on iMac 5K
                                      BCS Group Level 1
                                      This is Apple's stance on the Retina iMac and Adobe application problems.
                                      In this case, I would recommend considering postponing this purchase until more information about the issue and solution appear. I completely understand your satiation and am very sorry for this inconvenience, but I honestly cannot do much here when it comes to 3rd party program compatibility, as it depends on two parties rather than just the iMac
                                      • 16. Re: Terrible performance on iMac 5K
                                        Indesign is "okay" to use, but illustrator is horror on the retina iMac. I wouldn't get one if I were you..
                                        • 17. Re: Terrible performance on iMac 5K
                                          Marion49 Level 1
                                          This totally sucks! I guess I have to start at square one and return the machine - hope b&H will take it back!
                                          • 18. Re: Terrible performance on iMac 5K
                                            BCS Group Level 1
                                            Tell me about it. I was really looking forward to having a 5K display. I couldn't believe it when Apple's own support teams advised me to avoid the Retina iMac until the problems are resolved by Adobe. More amazing is that Apple’s newest desktop is marketed as being designed for photographers :-S
                                            After lots of reading & researching over the Christmas period, I opted for a new NON-Retina iMac with all the trimmings. It's a big step up from what I had before so I am happy.
                                            Fingers crossed that Adobe gets this fixed soon for the existing riMac owners.
                                            • 19. Re: Re: Terrible performance on iMac 5K
                                              Modesto Vega Level 2
                                              I don't know if I would return the machine as Marion49 says but the problem with the 5K iMac is the display, to be specific the resolution. At full resolution you are dealing with 5120x2880, 14.7 million pixels (8.8 million pixels if you run it at 4K, and 2 million pixels if you run it on HD). Just think for a minute what you are asking the computer and LR to do. My secondary display attached to a humble MacBook Pro has a resolution of 2560 x 1440 3.6 million pixels (and a pixel depth of 32-Bit Color (ARGB8888)).
                                              You could of course reduce the resolution to 4K or HD and see what happens.
                                              • 20. Re: Re: Terrible performance on iMac 5K
                                                Marion49 Level 1
                                                I tried some of the things mentioned, but left my resolution set high, and I ended up reducing the window size of LR by about 1/4 and now everything runs a lot smoother.
                                                • 21. Re: Re: Terrible performance on iMac 5K
                                                  robgendreau Level 3
                                                  The performance of LR on my retina is acceptable, it's only the transitions between adjustments that are ugly. I don't use it for slideshows, which also stink (I never used them on my other Macs so I can't compare). So I click the sliders instead of sliding them, and it works as fast as my previous iMac. I still have concerns over the speed of LR, but I had that before the riMac. And I'd trade that little niggle in a heartbeat for the superior screen; in terms of getting work done that has speeded things up considerably since I don't have to zoom all the time.
                                                  OTOH, if you have to use Illustrator, and it doesn't work, I guess you have no choice. Not as many alternatives for that. But there certainly are a lot of alternatives to LR. I'd dump LR long before I'd dump retina; it's the future. Maybe LR isn't the future.
                                                  • 22. Re: Terrible performance on iMac 5K
                                                    Marion49 Level 1
                                                    oh, I also changed the cache (preferences file handling) to 50GB. It was at 3GB...and someone suggested to even go up to 100GB, so I may try that if that will improve things even further. Hopefully, though, Adobe will end up fixing this problem with LR updates.
                                                    • 23. Re: Re: Terrible performance on iMac 5K
                                                      robgendreau Level 3
                                                      I'm not sure which window you speak of, but try scaling the image itself, say 1:2. And leave the Display prefs at "best for display." The image redraw is where the power is required; at 2:1 you are getting 4 pixels for each pixel in your image. Since the retina is so sharp, unlike previous monitors, you don't lose much by doing that. Took me a while to realize that scaling, especially integer scaling, looks great on the retina, unlike my previous Mac.
                                                      And consider the comparison with a regular iMac. My RAWs at 1:2 overflow the working area in LR on my iMac 2560x1440 display; at that same 1:2 on my riMac they are well within the area. I'm looking at doubled up pixels on both. And from 32" on the iMac it's the same resolution as 16" on the riMac. In short, you can duplicate the 2560x1440 display on the retina, and probably improve performance when editing, but you can't go the other way, and produce the riMac performance on the regular iMac, unless you're willing to sit 32" back to view your photos. You can just lean in on the riMac to see detail, so you really don't lose anything by using LR on an riMac over a regular iMac. So why ditch it unless you're going to say 4k on a nMP or something?
                                                      Also, I wonder if you use 1:1 previews when importing. That should speed things up, but since I use that by default I can't say. If LR has to generate one for a photo you wanna edit from a RAW that's a big slowdown.
                                                      • 24. Re: Terrible performance on iMac 5K
                                                        I've increased ACR cache to 100 GB and LR is now usable. I definitely notice more of a delay than I had with my previous iMac, and that is notable because my 5K iMac setup should be considerably faster. I had a 3 TB Fusion Drive on my last machine; now I have a 512 GB SSD and mu photos stored on a LaCie Big external TB2 drive with 1,300 Mb/s speeds.
                                                        I'm definitely hoping for improvements with the next update of LR, but I'm not giving my 5K iMac up anytime soon. Would be very difficult to go back now that I'm used to the resolution.
                                                        • 25. Re: Re: Terrible performance on iMac 5K
                                                          I think Rob is absolutely right, a 2560x1440 working area or even smaller needs to be reproduced.
                                                          Let's do some maths, I have a camera with a 24 megapixel sensor (and a little bit), it generates 6014 by 4016 images, on 2560 by 1440 I would need approximately 2.4 screen widths and almost 2.8 screen heights to see a photograph 1:1 (100% zoom). Now on a 5K screen (5120X2880) you need just over 1 screen width and 1.4 screen heights to see the photograph 1:1 (100% zoom). If you have a smaller sensor, about 16 megapixels, taking 4272 x 2848 photos, on a 5K you are making edits to your photos at 1:1 resolution (100% zoom) with the whole image visible on the screen; each time you make a global adjustment LR has to recalculate and the render the whole photo, every single pixel, and this could also apply to local adjustments. I do make some adjustments at 1:1 but only on my primary display which has a much smaller working area.
                                                          To view photos and videos at full 5K resolution is one thing, probably a great experience, to edit at full 5K resolution is a different matter and likely to require significant computer power (for calculating and rendering).
                                                          • 26. Re: Re: Terrible performance on iMac 5K
                                                            Marion49 Level 1
                                                            indeed a lot of math ...also not one of my strong suits
                                                            I have the D750, so I think I also have 24 megapixels, right? Anyway, I will try to wrap my head around what you said a little later. I have another issue that I need to research...LR will not open my file into PS - I will see if there is one already open on this. That issue did not go away by changing the cache and the size of the actual LR window.
                                                            • 27. Re: Terrible performance on iMac 5K
                                                              D750 is 24 megapixels, full frame.
                                                              Re LR not opening your file into PS. What version of PS are you using?
                                                              • 28. Re: Terrible performance on iMac 5K
        Marion49 Level 1
        I just downloaded the trial for CC both LR and PS, so it says Photoshop CC 2014
        • 29. Re: Terrible performance on iMac 5K
        You shouldn't have a problem, they should open fine. Do you get any error messages? In LR if you look under Preference\External file Editing what do you see?
        • 30. Re: Terrible performance on iMac 5K
        Marion49 Level 1
        I get no error; either nothing happens, when PS is already open or if not, it will open it, but the file will not show up. Here are my setttings:Screen Shot 2015-01-13 at 2.19.21 PM.png
        • 31. Re: Terrible performance on iMac 5K
        Marion49 Level 1
        It will let me drag and drop the file from LR into PS, but I never had to do that before on my old machine. I simply selected the files, right clicked, and went to 'edit in' PS and they would load...
        • 32. Re: Terrible performance on iMac 5K
        I don't think it is going to make a difference, if it does I am going to get worried, but I would change the Color Space to ProPhotoRGB (in particular, if you shoot RAW) and the Bit Depth to 16. This would be my standard settings. Again that should not change anything. If PS is not open, does it become usable immediately after opening?
        Since this is a new machine, I am assuming it runs Yosemite (10.1.1).
        • 33. Re: Terrible performance on iMac 5K
        Marion49 Level 1
        yes, PS is usable right away, and the machine runs Yosemite (10.1.1)
        about the color space... I just changed it to that since I ran into the issue of color being completely off from the new machine to my old one - meaning a file that I edited in PS on new machine looked horrible on my old one, all washed out and "dead" instead of vibrant. I have not calibrated the new machine yet, had too many other issues going on with it to spend time on it (especially because I have to look for my calibrator and the software). My old machine was calibrated, although it has been a while, but the pictures came pretty much back the way they looked on the screen, so I did not bother changing anything... I figured it had to do with the color space... although I am still not that happy and hope that will change after the calibration. Although PS was also really slow while editing and now that I reduced the size to 8-bit, it works faster again, but still frustrating because this is a new machine with new and fast components.
        • 34. Re: Terrible performance on iMac 5K
        teejten Level 1
        I'm guessing that all the 5k mac user's are trying to adjust the Performance settings in the Preferences panel.
        • 35. Re: Terrible performance on iMac 5K
        sunlit777 Level 1
        I think the memory leaks and general bad optimization for mac os is telling here. Just more noticeable. My Lightroom memory (RAM) utilization is quickly getting to over 6 GB (after about 5 minutes work, and no heavy-lifting at that, just browsing, occasional cropping and keywording of images). OVER 6 Gb, and with use it is getting more and more until I have to restart Lightroom because it is impossible to work any longer (too sluggish). Adobe, do something, start paying attention to Mac, the platform is growing!
        • 36. Re: Terrible performance on iMac 5K
        powellvu Level 1
        Now that LR CC (aka LR6) has been released, are people with the 5K still experiencing performance issues?  I just ordered a 5K, but if there continues to be issues, I might cancel the order and order the older model.
        • 37. Re: Terrible performance on iMac 5K
        sunlit777 Level 1
        The Develop module has got GPU acceleration, but for limited functions. E.g. cropping is now very smooth and fast, but retouching is still choppy. The rest of the interface, like Loop, grid, etc, is still slow and laggy. Very partial improvement to say the best. I have attached a second Cinema HD 30" display and do my LR work on it.
        • 38. Re: Terrible performance on iMac 5K
        xfshooter Level 1
        Has this issue been addressed yet? Very close to purchasing a 5K iMac, but not if Lightroom is still buggy. Thanks!
        • 39. Re: Terrible performance on iMac 5K
        MARIE DARE Level 1
        Hi I recently purchased a Imac 5k basic spec:
        • 3.3GHz quad-core Intel Core i5
        • Turbo Boost up to 3.7GHz
        • 8GB (two 4GB) memory
        • 1TB hard drive1
        • AMD Radeon R9 M290 with 2GB video memory
        ...and for a 1600 pound computer it was incredibly lagging on photoshop...for example dragging images around the clipboard... Indesign was slow scrolling between each page using a magic mouse... zooming in and out was near enough impossibly as it will zoom in too far (probably because it is delayed). My 2009 macbook, spec: 2.26 ghz intel core 2 duo 8gb ram with NVIDIA GeForce 9400M 256 MB graphics is actually quicker than the imac. I would like to ideally have a desktop as I am a graphic designer, but there is no point in upgrading if it is slower than a 6 year old macbook! Any help will be appreciated
        Also I was thinking of buying this, but I need to know if it will be worth it
        Refurbished 27-inch iMac 4.0GHz Quad-core Intel Core i7 with Retina display - Apple Store (UK)
        Marie
        1 2 3 Previous Next
