I have CS4 Design Premium. Went to use InDesign and it wouldn't open. So I tried reinstalling it. It won't reinstal. I unistalled it and it still won't install. Says instal is initializing but that's as far as it goes
rename OOBE Folder to OOBE.old.
to find OOBE:
64 bit OS: Program Files x86\Common Files\Adobe\OOBE
32 bit OS: Program Files \Common Files\Adobe\OOBE
I cannot find the OOBE file in the path that is given
what's your os?
Windows 7
Windows 8 sorry
you may need to expose hidden files,
Still no OOBE files to be found
then just clean your computer and retry, Use the CC Cleaner Tool to solve installation problems | CC, CS3-CS6
I'm a little reluctant to do that because Illustrator, Photoshop and the rest of Adobe is working fine. Seems the only issue is with In Design. If I uninstall the whole thing and then I can't reinstall any of it--then I'm completely out of luck.
you can try resetting your id preferences,
reset your preferences:
dreamweaver: http://helpx.adobe.com/dreamweaver/kb/restore-preferences-dreamweaver-cs4-cs5.html
flash: http://helpx.adobe.com/flash/kb/re-create-preferences-flash-professional.html
illustrator: Illustrator Help | Setting preferences
indesign: https://forums.adobe.com/thread/526990
lightroom: http://www.lightroomforums.net/showthread.php?14226-Resetting-%28or-Trashing-%29-the-Light room-Preferences-file
photoshop: https://forums.adobe.com/thread/375776
I have windows 8--the link only contained windows 7 instructions and I couldn't find cache after I opened version 6, en_US
google for help with that.
