Help! We have created a login for our users to insert records
into our database. The insert piece seems to be working well but it
is erroring our and appears that their session is timing out. I
attempted to make it so that it does not timeout for one day but
apparently coded it wrong. It works if you add records one right
after the other but errors out with error Element USERID is
undefined in Session if they let it sit for like 10 - 15 min or
longer. They potentially could be sitting for 60+ minutes at a
time. Can someone please help? Attached is my
application.cfm
You may want to check the session timeout in CF
administrator.
Regardless of what you make the session timeout to be in your
Appliction.cfm code, if the Maximum time in CF admin is defined as
(say 20 minutes), then that is what is used.
