Has been going on for months now, with no Flash. Have tried uninstalling, clean install, and the offline installer...but still always hangs up at 95% until I force quit. Help!?!
Hi davidd61713525,
What is the name of the installer file you are using? We have a few different installer files and this will identify which one you're using and enable us to better troubleshoot the issue.
Thank you.
Maria
The most current one I tried (yesterday) is <<install_flash_player_osx-2.dmg>> But I've tried many other versions previously.
Hi davidd61713525,
I'll need to get some log files from you to troubleshoot further. Please see Where do I find the Flash Player installation log on the Macintosh? and provide the install.log and FlashPlayerInstallManager.log file. Install.log file contains a bunch of stuff and we only need the Flash Player related content. This FAQ will describe how to obtain only the Flash Player related content. Since you're using the offline installer we won't need the ADM files mentioned in the FAQ. These files will be fairly large. Instructions for uploading the files are linked to at the bottom of the FAQ.
Thank you in advance.
Maria
Ok, I've uploaded the aa and aa files here: Shared Files - Acrobat.com
There were no dobe_ADM.log or Adobe_GDE.log files on my computer. Let me know if you need anything else
Hi Maria. Any updates on this?
Hi davidd61713525,
Sorry for not replying sooner.
The install.log file you provided only contains the following:
Apr 22 17:30:09 new-host-5.home installer[3288]: JS: Flash Player Install: Performing volume check for /Volumes/Time Machine Backups\
Apr 22 17:30:09 new-host-5.home installer[3288]: JS: Flash Player Install: Error: Non-OS Volume detected.\
Was there additional output in the log file that you didn't provide, or was that it?
Maria
Hi Maria - yes, I put in a placeholder in the install.log file, ran the installer, and that's as far as it gets.
Hi Maria. Any updates or help with this?
Hello?
Hi davidd61713525,
Sorry for not getting back to you sooner.
Unfortunately, it looks like something is wrong with the file system and the installer can't see the root drive to install to. A Google search returns numerous results affecting various products and the recurring theme is that something is wrong with the disk. There are many recommendations from various sources, but nothing definitive.
Here's a similar thread over on the Apple forums:
Broken Installer Permissions | Apple Support Communities
And a similar older one:
http://forums.macrumors.com/showthread.php?t=1203509
I would try the following options:
If these options do not work, I'd reach out to Apple support to see if they have a suggestion. If you do find a resolution to this, please let me know. I'll be happy to share it with people that encounter the problem in the future.
Maria
See the "Try Disk Utility" section:
https://support.apple.com/en-us/HT203176
While you're there, choose Repair Filesystem Permissions (Verify will frequently return clean, but then Repair will still fix a bunch of problems).
