6 Replies Latest reply on May 19, 2015 8:44 AM by try67
    I have the code, I can't figure out how to write to a text field in Adobe.
    rhcross519
      I want to find if a number is in a certain range, if it is within that range I want it to assign a field a certain percentage.
      Here is the code:
      // Define Vars
      var TotalScore = this.getField("Total_Scores").value;
      var HighA = this.getField("Range_2").value;
      var LowA = this.getField("Range_1").value;
      var HighB = this.getField("Range_4").value;
      var LowB = this.getField("Range_3").value;
      var HighC = this.getField("Range_6").value;
      var LowC = this.getField("Range_5").value;
      var HighD = this.getField("Range_8").value;
      var LowD = this.getField("Range_7").value;
      //This is the increase
      var Rate1 = this.getField("Salary_1").value;
      var Rate2 = this.getField("Salary_2").value;
      var Rate3 = this.getField("Salary_3").value;
      var Rate4 = this.getField("Salary_4").value;
      //This is where the end Value will go
      var IncreasePer = this.getField("Increase_Per").value;
      //if Statement
      if (TotalScore >= LowA && TotalScore <= HighA){
      IncreasePer.value= Rate1;
      if (TotalScore >= LowB && TotalScore <= HighB){
      IncreasePer.value= Rate2;
      if (TotalScore >= LowC && TotalScore <= HighC){
      IncreasePer.value= Rate3;
      if (TotalScore >= LowD && TotalScore <= HighD){
      IncreasePer.value= Rate4;
      I am trying to do a Merit Increase form where the Employee's overall score puts them into 1 of 4 categories. The percentage numbers are just random numbers that we came up with to test the form.
      FromTo% of Raise
      40505.0
      30392.5
      20291.0
      10190
      090
      Any help or Insight is appreciated!
