Jean
You say "In the time-is-of-the-essence job I have, "just try
it both ways and see" doesn't work for me." Unfortunately those of
us who support the forum are also in "time is of the essence jobs".
Is there one that isn't? As a result, we simply do not have the
time to look at this area. We already spend more time than is good
for us supporting the forum and maintaining web sites to help. Like
Rick, I just do not have the time to research this area,
particularly as I would be starting from scratch as this is not an
area relevant to my work.
In point two, are you saying the output is not 508 compliant?
If you are, then clearly you have researched that much and if you
post how, I will be happy to relay that to Adobe. That said, it is
best that you also submit a bug report as they DO all get read.
I agree the online help could do with some more detail and I
will bring that to Adobe's attention. Again though, you should
submit a bug report on that too.
I will see if I can obtain any more information on this area
from Adobe but I make no promises.
As to irreversibly changing your project, that I can confirm
is a No. When you generate an output of any sort, no changes are
made to your source files. What happens is that the wizard notes
your settings and generates the required output. So if you select
508 Compliant it will give you one output, if you don't, then you
will get a different output. Your source files do not change at
all.
If anyone wants to write a topic on this area, I will be more
than happy to publish it on my site, subject to my right to edit
it!
