I was on a few days ago with issues concerning spreadsheets when moving from RH Word to RH HTML...First I should have said tables..they start off as spread sheets but are dropped in as tables in RH Word.....Well I figured out how I can convert my 100,000 link RH Work to RH HTML..and make functional and updateable. When you enter a new topic choose New Topic With..and choose Word. It allows the functionality I need (adding lines, sorting, etc) but I can use RH HTML.
My question is, Is there a way to set WORD as the default editor for RH HTML? It would be nice if I could do that.
It is going to be a tedious process to get it moved over (have to copy and paste a lot not to loose 100,000 plus links) but once it is set up the hard part is over. I just have to update the pages twice a month.
Hi there you brave soul! (working with Word)
Try clicking Tools > Options > File Association and you should be able to configure Word as an editor and also set it up as the default.
Post back if you get stuck! Rick
Thanks! I will try. Have to work in Work for this one project because of the tables and the sorting and the 100,000 plus links.
Thanks Again.
