broken TOC link
May 22, 2015 May 22, 2015
I had a RoboHelp HTML project that was looking great. However, I must have accidentally deleted a graphic and a Heading 1 in the section topic. Although the Heading 1 name is still in the TOC, the link to the heading is broken.
Also I still have the graphic that was accidentally deleted, but I am unable to add it to the topic.
Please help
396
Contributor , May 22, 2015 May 22, 2015
Could you just re-add the bookmark in RH to the existing topic?
Hi there
For the image, perform the steps you would normally perform to add an image. In the ensuing dialog, click the File Browsing link (shown below) and navigate to the project folder and you should see the image there.
Cheers... Rick
Contributor ,
For the linking to the TOC, just drag the topic from the topic list over to your TOC. Verify that link works and then just delete the TOC topic that doesn't link.
Thank you for your suggestion. I will try this but I am afraid. The topic is 50 FrameMaker pages in length and the broken TOC is to a bookmark. If the topics were smaller in scale, this may be a great way to fix my issue. But I am afraid of using this technique with a bookmark. But I will back up what I have and try it in a way so i can go back to the original version if it doesn't work.
Contributor ,
I believe that if I could readd the bookmark, I may be all set. However, I don't know how to re-add a bookmark. Can you please provide a suggestion?
Betsy, you mentioned using FrameMaker? This would seem to suggest that you are either importing from FrameMaker or linking to a FrameMaker file. And if that's the case, you have to make the change over in the Frame universe. If that's the case, someone with Frame knowledge will have to advise on how that happens.
If you are staying in RoboHelp, position your cursor where you want the bookmark to be inserted, then click the Insert menu and you should see Bookmark as an option.
Cheers... Rick
Thank you so very much for suggesting how I could fix the broken link in my TOC. Instead of dragging the topic from the Topic List, I dragged the bookmark to the heading from the Project Management pod. I regenerated and it worked!!  My TOC is working now. Thank you again.
Contributor ,
AWESOME!!! Whew, eh?!!
As far as my missing graphic, I copied the missing graphic from a previous version of my project. Then I imported it by reference. I will see it things are OK after I regenerate. But I believe I am OK with my graphics issue.
Thank you!
Contributor ,
Also, as a last resort you could always open the image, copy it and then paste it into the topic.  (If you aren't able to insert it.)
While true, that it's possible to copy and paste, it's a horrible, Horrible, HORRIBLE way to work that I never recommend.
In life we are always making sacrifices. Want more money? Sacrifice time doing leisure things. Want more time? Sacrifice making money. The list goes on and on and on.
When you copy and paste an image, you totally sacrifice any ability to choose the image format. RoboHelp will make that choice for you. RoboHelp will also choose the name of the image. And that name will in no way reflect what the image is about. True, you will be able to rename it in RoboHelp, but I'd always prefer doing all that in my image capture and editing applications.
Cheers... Rick
RoboHelp Documentation
Download Adobe RoboHelp
