Hi All,
I have created a workflow launcher with reverse replication for user generated content(/content/usergenerated). Newly created node is reverse replicating properly but the properties in the nodes are not reverse replicating properly. I am using the out of box form components and am just updating the Action type of the form.
In Publish
Event : Created
Nodetype : sling:Folder
Path : /content/usergenerated(/.*)
Workflow: Reverse replication
Runmode : Publish
In Author
Event : Created
Runmode : Author
Anything missing here? Can Anyone please suggest me to proceed further?
Deepan.
Total Likes
Hello,
I think you are not saving the newly created nodes BEFORE you add the properties. Reverse replication won't work without the nodes being saved. So after the nodes are created in your code, add something like this code:
Node contentNode = pageNode.addNode("jcr:content", "nt:unstructured");
session.save()
After doing the save, then add the properties:
contentNode.addProperty("");
Hope that helps.
Total Likes
Hi Deepan
Can you please go through the knowledge base[1] and verify if you have followed all the steps mentioned therein?
It's important to set cq:distribute property on your nodes that you would like to reverse replicate.
Please confirm and let me know.
regards
Varun mitra
Total Likes
Hi Jtalbot,
Nodes are saving properly in publish server and also reverse replicated properly to Author. But the properties are not reverse replicated, All the properties are missing in the Author Instance.
Deepan.
Total Likes
Hi Deepan,
Please check if the reverse replication logs if any thing is stuck. We can try clearing the queue and check.. Jst a thought..
Jaison
Total Likes
