Follow-up to previous question regarding CFC functions
May 22, 2015 May 22, 2015
Hello, all,
Earlier, I had asked a question about methods not being found in components.  haxtbh‌ pointed out something that I had skipped over (I was in a hurry) in the documentation - that 'private' methods (even within the same CFC) cannot be referred via the "this" scope.  I changed all of my methods to be called via mapping (ie, "components.componentName().methodName(args)") and most of them work!  However, I've got a few that aren't being found, even with using the mapping.  I really do not want these methods to be pushed into "public" access; I would much prefer that functions called from within the same CFC be private.  Any suggestions on what could be causing these to not be found?
V/r,
^_^
247
May 24, 2015 May 24, 2015
WolfShade wrote:
... I changed all of my methods to be called via mapping (ie, "components.componentName().methodName(args)") and most of them work!  However, I've got a few that aren't being found, even with using the mapping...
Just use the obvious, standard way,
<cfset obj = createobject("component", "dotted.path.to.componentName")>
<cfset result = obj.methodName(args)>
It leaves no room for ambiguity or error, and makes your code easier to understand and to maintain.
May 28, 2015 May 28, 2015
Hi, BKBK‌!
Thanks for replying.  I'm not sure if we're allowed to use CreateObject on the production servers.  And I'm trying to do this via CFSCRIPT as it appears a little cleaner than having all those CFSET tags.  Normally, I don't mind the HTML-style tags, but sometimes I just want less clutter.
V/r,
^_^
May 25, 2015 May 25, 2015
I understand that you want to call your private method inside of the CFC.
I do this direktly by using the method name without any prefix:
          methodName()
This works well for me.
Hi, j.herden‌.
You don't use "new" or anything to make sure that the current CFC is referenced?
V/r,
^_^
Documentation
