I am using iMAC and have problem w my ADE after installed latest version 4.0. Please help!
Error MSG: Unable to download, Error getting License. License Server Communication Problem: E_ACT_NOT_READY
I have checked Authorized Information. Everything looks ok.
For this problem, you need to deauthorize and authorize ADE again.
Launch ADE
Help -> Erase authorization.
ADE will be deauhorized.
If due to some reason, you are unable to deauthorize ADE, follow the below steps:
Windows:
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key:
HKEY_CURRENT_USER\Software\Adobe\Adept
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Your authorization will be deleted.
ADE will be deauthorized now.
Now Authorize ADE again. [Help ->Authorize Computer]
Hi Shreya,
I have tried your method, but it is not working.
I clicked on "Erase Authorization", the system prompt a message "ADE 4.0 wants to use your confidential information stored in "Digital Editions" in your keychain. Do you want to allow access to this item?" I have tried "Deny" AND "Allow".
Unfortunately, system prompt an error message (in red) : Unable to Erase Authorization. Please try after some time."
Tried many times, not working.
Please advise...preferably a step-by-step instructions as I am a new iMac user.
Thank you.
1. Press keyboard shortcut: cmd+shift+g.
Go to folder dialog will appear.
2. Type ~/Library/Application Support/Adobe/Digital Editions
drag the activation.dat file to the trash.
Now Authorize ADE again [Help -> Authorize Computer].
Hi Shreya,
Your method does not work at all. I opened ADE, then press shortcut: cmd+shift+g, nothing comes out.
Is there other way to do it (I am using iMac OSX Yosemite, Version 10.10.3)
Please advise (preferably a step-by-step instructions).
Thanks.
Amanda
Hi Shreya,
I managed to reactivate my ADE Authorization now! Just need to press shortcut: cmd+shift+g on the desktop not on ADE.
Thank you!
Regards
Amanda
