returning function value
Guest
Dec 13, 2007 Dec 13, 2007
this is my .cfc
<cfcomponent>
<cffunction name="httpTransaction" access="public"
returntype="string">
<cfargument name="USER" type="string" required="yes">
<cfargument name="VENDOR" type="string" required="yes">
<CFHTTP url="" method="post" resolveurl="no" timeout="30"
<CFHTTPPARAM type="header" name="X-VPS-REQUEST-ID"
value="#CreateUUID()#">
<CFHTTPPARAM type="header" name="X-VPS-CLIENT-TIMEOUT" value="30">
<CFHTTPPARAM name="USER" type="formfield" value="#USER#" encoded="no">
<CFHTTPPARAM name="VENDOR" type="formfield" value="#VENDOR#"
encoded="no">
</CFHTTP>
<!--- how do i return the value --->
</cffunction>
</cfcomponent>
and I'm trying to pass the
<cfoutput>CFHTTP.FileContent#</cfoutput>to the page that is invoking
the above function.
Advanced techniques
679
Participant , Dec 14, 2007 Dec 14, 2007
Look -- your httpTransaction() function is returning a string. That string is referenced in your code as 'myResult'. Therefore, just change this:
<CFSET content = #myResult.fileConent#>
<CFOUTPUT>#content#</CFOUTPUT>
to this:
<cfoutput>#myResult#</cfoutput>
RTFM
<cffunction ...>
<cfargument1 ...>
<cfargument2 ...>
<cfset var myResult = "">
<cfreturn myResult>
</cffunction>
hth
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
I think it's only appropriate to return the cfhttp entity that Coldfusion creates after running the tag. I think its a structure, but can't recall now. So I use type "any". The result is:
returntype="any" output="false">
<!--- ... etc., etc., ... --->
<cfreturn cfhttp>
</cffunction>
On the calling page you would then have:
<cfset httpObj = createobject ("component", "component_path")>
<cfset myResult = httpObj.httpTransaction(myUser, myVendor)>
<cfset content = myResult.fileContent>
P.S.
- give url attribute a value;
- scope your vars, hence arguments.USER and arguments.VENDOR
Guest
I'm a little confused on:
are the variables "myUser", "myVendor", coming from the scope of the values that we've already passed to the cfarguments? I'm wondering if we are passing those same variables again?
thanks,
Guest
Wait. I think I spoke too soon. I'll try something. It's usually after you move the piece that you see it's a bad move.
Guest
OK, it all made sense, but I have one last question. I'm getting this error message,
"You have attempted to dereference a scalar variable of type class java.lang.String as a structure with members".
He is what we put together:
<cfset requestData = StructNew()>
<CFSET requestData.VENDOR = "john">
<CFSET requestData.USER = "doe">
<CFSET httpObj = createObject("component", "Caller")>
<CFSET myResult = httpObj.httpTransaction(requestData.VENDOR,requestData.USER )>
Participant ,
to this:
Guest
You rock. Thanks for the inspiration!!
Dec 15, 2007 Dec 15, 2007
Error message:
I advised you to return the struct cfhttp, but you continued to return a string instead. Hence the error.
I think it's much better for your code to return the cfhttp structure rather than a string. Just change the return type to "struct" or to "any". Then let the function end with: <cfreturn cfhttp>.
There are at least two good reasons to return a structure. First, you thereby make much more information available to the caller. Secondly, it enables the calling page to do some validation, for example, like this:
Documentation
