Hi
I am using AMS 5 and try to use http HLS streaming for mobile iOS devices.
When i try to open hls stream url http://host-namel/hls-live/livepkgr/_definst_/liveevent/livestream.m3u8 I have note like "livestream.m3u8 was not found on this server".
http://host-name/hds-live/livepkgr/_definst_/liveevent/livestream.f4m shows
<manifest xmlns="http://ns.adobe.com/f4m/1.0">
<id>livepkgr/events/_definst_/liveevent</id>
<mimeType></mimeType>
<streamType>live</streamType>
<duration>0</duration>
</manifest>
When I starting streaming via FMLE in AMS live logs i see
Stream name is: liveevent and live event is: liveevent
f4f:liveevent - NetStream.Data.Start
f4f:liveevent - NetStream.Publish.Start
f4f:liveevent - NetStream.Play.Reset
f4f:liveevent - NetStream.Record.Start
f4f:liveevent - NetStream.Codec.Error
But there is no information about .m3u8
I am using default adobe configuration with appache included to AMS setup.
What can by the reason of not working HLS.
Also can't find information about hls in appache logs
Sorry for my english.
Okay, thats looks good.
m3u8 is a kind of playlist where the player get meta information to play different chunks in the correct order to display a livestream.
At the beginning you have to wait for some seconds (i think 30 by default) that the AMS can render these chunks.
M3u8 Url´s can only be displayed in specific players (such as JWPlayer) or on native browsers like Safari (osx / ios). I am not sure about playing m3u8 Url´s on Android devices.
But I you enter this URL into your safari on a mac or
...Copy link to clipboard
Hej Tomasz,
which tool do you use to stream to your AMS?
Could you please provide some informations about your settings regarding camera and microphone (codecs etc).
As you can see in your logs, there seems to be a problem with the codec.
I tried the default application with the Flash Media Live Encoder with a H.265 5.1 Profile and AAC Stereo audio - works like a charm.
You will never find the m3u8 files directly in your directories.
The apache module will generate some meta data such as .control .bootstrap .f4x files which will be provided over the m3u8 URL (automatically).
Best,
Patrick
Hej Patrick
Thanks for you response. I reinstalled Flash Media Server
I try to use two streamers Adobe Flash Media Live Encoder with H.264 settings for video
and Teradek VidiU HDMI H264 Live Streaming Encoder
AMS log shows :
onPublish : liveevent
I found that when I open http://host-name/hls-live/livepkgr/_definst_/liveevent/liveevent.m3u8 then m3u8 file exist.
So it looks like the hls module works fine.
On m3u8 looks like:
#EXTM3U
#EXT-X-MEDIA-SEQUENCE:260
#EXT-X-ALLOW-CACHE:NO
#EXT-X-VERSION:2
#EXT-X-TARGETDURATION:8
#EXTINF:8,
../../../../hls-live/streams/livepkgr/events/_definst_/liveevent/liveeventNum260.ts
#EXTINF:8,
../../../../hls-live/streams/livepkgr/events/_definst_/liveevent/liveeventNum261.ts
#EXTINF:8,
../../../../hls-live/streams/livepkgr/events/_definst_/liveevent/liveeventNum262.ts
#EXTINF:8,
../../../../hls-live/streams/livepkgr/events/_definst_/liveevent/liveeventNum263.ts
#EXTINF:8,
../../../../hls-live/streams/livepkgr/events/_definst_/liveevent/liveeventNum264.ts
#EXTINF:8,
../../../../hls-live/streams/livepkgr/events/_definst_/liveevent/liveeventNum265.ts
But I still can't find solution how to open or test this stream video on non flash devices.
But I you enter this URL into your safari on a mac or iphone / ipad, you will see the livestream.
Another issue could be the "fullscreen" mode, which is forced on iOs for some reasons. On the iPad you can play the stream inline as well with a additional Parameter (webkit-playsinline="1" -> Only works on ipad).
Hope thats helps a bit ... If you do not have any OSX / IOS device for testing, just start a stream and send me your url via private message. I can test for you if you like to
Hi
I test in on physical iOS device and stream works fine.
Big Thanks for your help !
