Assign a user-script to a button
Guest
May 28, 2015 May 28, 2015
How can I assign a button to a .jsx for quicker access? Currently I have to use 6 mouseclicks and 3 keyboard strokes!!
445
Deleted User
May 31, 2015 May 31, 2015
Well... your description was not helpful at all.. but:
The user script has to be copied to the write protected folder "%programfiles%/abobe/.." where all the other scripts can also be found.
Honestly: this is not user friendly, but it works somehow at least.
Hi there
First off, I need to ask if you are using the Adobe RoboHelp application to author help files? If not, you are in the wrong forum.
If you are using Adobe RoboHelp, can you perhaps fill in some detail about exactly what you are doing?
Cheers... Rick
Guest
I am in the right forum.
Sorry for the confusion, but I do not know any other way to write a "user script" than Javascript. So I wrote a .jsx for RH and I want to assign it to a button now.
Okay, cool.
Will the button be in the body of a topic? In the toolbar of WebHelp? Where will it be?
And what about the script? Is it just a block of code that is self contained? Or did you put it in a .JS file that you now want to include in the project?
And about the file itself. I'm not sure I know what a .JSX file is. Special form of JavaScript?
Cheers... Rick
Guest
I am talking about using Menu | Tools | Scripts | Browse...
Some scripts are already pre-assigned from RH but how can user-script be assigned?
Hmmm, okay
The scripts you see when doing that are scripts you execute to influence changes in the RoboHelp editing environment. They aren't scripts that an end user of your help system would have access to. I just wanted to ensure we are on the same page for that.
Assuming you were already aware of this, I'm guessing you are trying to add a button somewhere in the RoboHelp editing environment to launch a script?
Cheers... Rick
May 29, 2015 May 29, 2015
Currently, you can't influence the UI with script or link a button to a script.
What may help is to open the Script Explorer Pod. That will eliminate a few clicks.
You may also want to look into RoboHelp Scripting Events. These events fire after certain actions. You can have your scripts run automatically when an event occurs. The following link may be interesting: Using the new RoboHelp 10 scripting events | Adobe Developer Connection
Well...
You actually *CAN* link a toolbar button to a script.
Right-click the toolbars and choose Customize... Then from the Customize dialog, click the Commands tab and find the Scripts item on the left side. Click the script you want and drag it from the dialog to the Toolbar.
If you want to see an image in the toolbar instead of the script name, right-click the new area in the toolbar and choose an image.
Cheers... Rick
Guest
Sooo, were you then able to assign the script to a button like you want? What part wasn't helpful?
Guest
I agree, I was able, but your text did not help me, as the solution was to copy the script to a certain directory - which is nowhere documented.
Nevertheless I appreciate your detailed documentation which might be helpful for others.
THANK YOU!
Jun 01, 2015 Jun 01, 2015
Well I'm pleased you managed to get it sorted.
However, I have to say I disagree with your statement: "as the solution was to copy the script to a certain directory - which is nowhere documented."
In RoboHelp 11, I clicked the Help menu and opened the help system. (Help > Contents&Index).
From there I clicked the Search icon and typed "Script".
The second result listed was "About ExtendScript Toolkit support".
After clicking that link and reading through the topic, I noted this:
So it does actually appear to be documented.
Perhaps it might be more easily found. But I'm not sure how.
Cheers... Rick
Nice! Missed that one!
RoboHelp Documentation
Download Adobe RoboHelp
