1. Re: How can I import Arabic text from MS Word without InDesign reversing and breaking the text?
Ellis home May 28, 2015 6:08 PM (in response to johns71555071)Check here and let us know if it helps: Arabic character period in the wrong spot?
2. Re: How can I import Arabic text from MS Word without InDesign reversing and breaking the text?
johns71555071 May 28, 2015 6:15 PM (in response to Ellis home)Thanks for your reply. It's not a problem with the periods though, but the entire text changing. So "Hello" becomes "O L L E H". The text is backwards and spaced out, not connecting like Arabic should.
Someone has told me I need to find an option called "Change paragraph" or similar but it doesn't seem to be available. Someone else has told me a need to find an equivalent of changing the 'text engine option' in photoshop to Middle Eastern.
Please let me know you have any tips. I know this is a common problem with Arabic text.
3. Re: How can I import Arabic text from MS Word without InDesign reversing and breaking the text?
Ellis home May 28, 2015 6:28 PM (in response to johns71555071)Did you try what it's suggested? It usually works. Give it a go. Otherwise you need to either download a MENA version (CC subscribers have access to it) or buy a plugin like the one from In-tools.
5. Re: How can I import Arabic text from MS Word without InDesign reversing and breaking the text?
johns71555071 May 28, 2015 6:32 PM (in response to Ellis home)Ok, I will give it a try and let you know how it goes. Thanks for your help
