Installed Cold Fusion 11 standard, on window 2008 R2 and it will not serve up .CFM tags that are not in the root directory of a web site
What error are you getting?
Is this IIS or Apache? Did you run the web connector tool?
Do you have any mappings setup? Is there an application.cfc?
I assume you are talking about cfm files in sub folders to the root and not somewhere completely outside of the root.
IIS, Windows 2008 R2 ,,, did run the connector, the localhost/cfide/administator/index.cfm and all its files work fine.
However, all the other web sites on that machine will only run the default index.cfm once and only when called like : http://mysite.com, if the default is index.cfm .. it will run fine, however no other .CFM page will run, and if you go to another directory to an .HTML page, and it has a home button, the INDEX.cfm will not run called from inside the web site. The error was 404 file or directory not found
Was the other sites added to IIS AFTER installing coldfusion and running the web connector?
If so, and probably worth doing anyway. Run the connector again (as administrator), remove what is existing and re add the IIS sites to it.
No all the sites were running before the cold fusion installing .. the server was a BlueDragon coldfusion unit, we installed CF 11 to fix an issue with Authorizenet
Probably worth re running the connector if you haven't already. Also as mentioned in previous post, did you have mappings set up in your existing coldfusion setup?
Have done the connector about 6 times, only mapping is the CFIDE and Gateway
Can you share the screenshot if error message you are getting?
Anit Kumar
