9 Replies Latest reply on Jun 1, 2015 12:25 PM by CPedrick
    .$("elementName") vs .getSymbolElement() - what is the difference?
    CPedrick Level 1
      I have a symbol called Chart on the main stage, along with a symbol called Dot in the library. Dot contains an element (just a basic rectangle) called "bar".
      I wanted to dynamically create a couple of copies of Dot, with it's element bar on the main stage. I could create the copies just fine using the code shown below, but they did not line up correctly vertically. Each copy dropped down the stage by a bit.
      var Bars = new Array();
      var xPos = 8;
      for (i=0;i<3;i++){
         Bars[i] = sym.createChildSymbol("Dot", "Chart");
         Bars[i].$("bar").css ('position', 'absolute');
         Bars[i].$("bar").css ('left', xPos);
         xPos = xPos + 40;
        } //end for
      It drove me nuts. I tried including the following to force the Y position:
          Bars[i].$("bar").css ('top', yPos);
      That made absolutely no difference at all. It drove me nuts.
      Finally, I changed the code in the loop to:
               Bars[i].getSymbolElement().css("position", "absolute");
               Bars[i].getSymbolElement().css("left", xPos);
               Bars[i].getSymbolElement().css("top", yPos);
      That lines everything up perfectly.
      I am thrilled that I have a solution, but now I also have a question:
      Why does the syntax Bars[i].$("bar")  not work, but the syntax Bars[i].getSymbolElement()  positions things correctly?
      Even more importantly, what if I had two elements within the Dot symbol and wanted to position them independently of each other? How would I address them by name or ID to differentiate them?
      Thanks for any light anyone can shed...
      Carolyn
