Replace an entire topic
Guest
May 28, 2015 May 28, 2015
Can I update/replace an entire topic somehow?
Background: I have a word main doc with links to sub-docs. For RH usage all sub-docs have to be merged to one main word-file (otherwise RH reports an error) before. Then I import the big main wordfile into RH which creates all topics (and images, index,..).
If I later want to change just one sub-doc I have to redo all the previous steps?!
How can I import just such a sub-doc to RH and then replace in the main-RH file (including all the image, links)?
231
May 29, 2015 May 29, 2015
You can link (not import) each individual document in RoboHelp. Whenever one of the documents changes, you can simply regenerate the topics.
I don't believe sub-docs are supported by RH and I doubt they will ever be. Sub-docs are a fool proof way of corrupting Word documents, but perhaps MS changed that in the 2013 version. Personally, I would always advise against sub-docs. If you need this kind of flexibility, I would recommend taking a look at FrameMaker.
Guest
May 31, 2015 May 31, 2015
Will the "RH linkage" also consider index and toc entries? I never tried before.
If you write >800 pages of documentation, sub-docs are the only way to keep things fast and stabe in word. I use this sub-doc procedure since >15 years with different authors and translation
offices.
Jun 01, 2015 Jun 01, 2015
You can convert the index and TOC as well. It's a bit more hidden because you first link the document and then choose to convert the index/toc.
I know the pain of long documents in Word. If you have no problems with subdocuments, you're either extremely good with Word or extremely lucky! I hope for the first. Personally, I live by the advice given here: http://www.addbalance.com/word/masterdocuments.htm
Guest
Jun 02, 2015 Jun 02, 2015
I gave it a test and it does more or less what I need. But: why are the HTML output files using "WD_" as prefix to all CSS formats I defined in the .ISF file? How can this be turned off, since when I manually import a word file, it does not happen. I hope I do not have to write another .JSX again..
RoboHelp Documentation
Download Adobe RoboHelp
