Hi bobmcinnis,
In order to offer a better way, I seems important to know
what "way" you are trying now. If I understand what you are trying
to accomplish, I think I would add the audio a single slide at a
time - obviously from a written script, to accomplish a degree of
consistency and professionalism in the result. One consideration
would be that, instead of entering varying times for each slide, I
would leave all slides at a default value of, say, 4 seconds. They
will adjust themselves later to the audio you enter on each.
I would write a script for the movie, then put the text
portion for each slide into the Slide Notes for that slide. During
the actual recording (Audio > Record > Project), you can use
Slide Notes (bottom of the record audio dialog) for your guide for
the voice-over.
**Before beginning the actual recording, un-check the
"Continuous Recording" option at the top of the audio recording
dialog. That will allow you to record and re-record the audio for
each slide, if that is necessary, before moving on to the next
slide.
When you are ready to move to the audio for the next slide,
just click the small blue "Next" arrow-button to the right of the
"Record" buttons. Do this through the entire presentation. Each
slide will automatically adjust to accommodate the length of audio
file you have placed on each during recording, as mentioned above.
EDIT:
All of this must be preceded by duplicating the click-box on
each slide as many times, and at whatever intervals as is required,
to synchronize the slide and audio to the animations contained on
the slide
(hope that makes sense to you - easier to do than to describe,
sometimes)
What I am suggesting is going to be a lot of hard work. It
cannot be avoided if you wish to use preexisting Power Point
presentations as the basis for your Captivate movies. The "hard" in
"hard work" is because the Power Point slides are being imported to
Captivate, each one as a separate "animation". Synching the slide
animation with the audio is the challenge ... and in many cases,
isn't worth the effort.
Good luck in whatever you choose to do!
