My Flash Player was installed and worked nice, until yesterday. But now it's simply gone in Chrome and won't be installed again!
I followed the step explained in Re: FP17 Pepper debugger fails to install on Chrome 42 (OS X 10.8.5), and now Flash Player plugin simply fails to be loaded.
Also installed Flash Player (PPAPI) debugger does not appear in chrome://plugins result.
Google's bundled player works fine, but hey, you cannot debug with it!
What I tried:
* uninstalled and re-installed Flash Player debugger, not works. ("not works" means file swapping in the article above does not work, and the plugin does not appear in chrome://plugins )
* uninstalled Chrome and Flash Player and re-installed both of them, not works.
* uninstalled Chrome COMPLETELY WITH ITS ALL ADDED-ON PLUGINS and Flash Player, and re-installed Chrome and Flash Player (namely "Clean Install"), not works again.
Hi Lucia Ellan,
It seems Google has disabled the non-embedded PPAPI plugin in the latest version of Chrome (43). The same PPAPI plugin version works in Chrome 42 but not Chrome 43.
I looked at Piyush's instructions (comment 20) at Re: FP17 Pepper debugger fails to install on Chrome 42 (OS X 10.8.5) and noticed an error with step 3. Since Google Chrome is a 32-bit app (indicated by it being installed to Program Files (x86) on a 64-bit OS), 64-bit OS directory path and file should be C:\Windows\Sy
...Copy link to clipboard
Additional info: 2 more people in my development team have reported exact same issue after updating to Chrome 43. I'm going to report this to Chrome forum too.
Hi Lucia Ellan,
I looked at Piyush's instructions (comment 20) at Re: FP17 Pepper debugger fails to install on Chrome 42 (OS X 10.8.5) and noticed an error with step 3. Since Google Chrome is a 32-bit app (indicated by it being installed to Program Files (x86) on a 64-bit OS), 64-bit OS directory path and file should be C:\Windows\SysWow64\Macromed\Flash\pepflashplayer32_<current version>.dll, not 'C:\Windows\System32\Macromed\Flash\pepflashplayer64_<current version>.dll' which is the 64-bit PPAPI plugin. I have fixed the directory path in the original post to the correct 32-bit directory path on 64-bit OS. I have confirmed these instructions on Windows 7 with Chrome 43 and the PPAPI debugger was recognized.
Alternately, Opera also uses the PPAPI plugin and you can try using that for debugging purposes as well.
I also recommend filing a Google bug at Report an issue - Chrome Help.
Maria
Thank you for correction on that step, Maria!
That solved (at least temporally, I mean, until Google resolves this) the issue. I already piled a report to the Google Chrome forum
I wrote this issue at Google Groups and the guy there suggested me to look at Issue 478056 - chromium - Flash player content-debugger does not appear in chrome://plugins/ - An op... , which is basically a MAC issue of same thing, but in Chrome 42. Also it worths to note that the issue is already more than a month old.
Hi Lucia Ellan ,
Thanks for the update. It's interesting that Google pointed you to the Mac bug. Google hasn't enabled the non-embedded PPAPI installer on OS X. Since it worked before on Windows, but isn't working now, I consider this to be a new bug. I did escalate this issue to our Product Manager last week and will forward him your latest comment with Google's suggestion.
If you do have a new bug number for the Windows issue, please send it to me and I'll forward it to our Product Manager to follow-up with Google.
Thank you.
Maria
Your solution seems promising, but your instruction are incomplete and I can't reproduce any success. Please provide us with the well defined steps, it will be usefull to the adobe/chrome dev team that seem to not have a hang on it.
Best regards
I'm running Win 8.1 64bit, and Chrome which is installed in "c:\Program Files (x86)\Google\Chrome\", however Windows Task Manager ('platform' column) reveals it's a 64-bit process. To make the Flash Player Debugger work I did the following:
Hi Milos-MAD,
Thank you for the feedback. I updated the instructions on the other thread with the 32-bit and 64-bit Flash Player locations on a 64-bit OS.
On a 64-bit OS, the 64-bit files are located at \Windows\System32 and the 64-bit files are located at \Windows\SysWoW64. SysWow stands for Windows 32-bit on Windows 64-bit (WoW64 - Wikipedia, the free encyclopedia). While it does seem illogical, it's the way Microsoft build it.
Thanks again for the feedback.
Maria
