Hi
I've managed to change location all coldfusion log files for naming instance but not ex catalina.out files: catalina-out.log and catalina-error.log.
Anyone has any idea where settings are ?
The only solution works so far
redirect 1>>STDOUT.file 2>>STDERR.file and remove default log file folder..
Can you have a look at Deeper insights into ColdFusion logging mechanisms — Adobe ColdFusion Blog , and see, if that helps.
Anit Kumar
I usually create my own logs and leave the predefined ColdFusion logs alone. I created a wrapper around the log4j library the CF uses. Google "ColdFusion log4j" and you'll find quite a bit -- maybe even a post or two from me that explains this further.
