I keep having trouble installing the adobe flash player, because right as it's starting to download it stops and prompts, "not enough permissions to write disk." What do I do?
Flash Player installs to restricted areas of the file system and thus requires Admin permissions to install.
What OS is this on? Is the user ID you are using to install a standard user or an administrator user?
Maria
The OS version is 10.10.3, is that the right thing? I didn't know there was a difference, I suppose. It's making me give my computer password to install, so I'm assuming that makes it an Administrator install? But once I put in my comp password, shouldn't that let it install?
Hi nuk473
Since Flash Player installs to protected system file locations OS X will always prompt for a password. Your User ID may or may not be an administrator. You can check to see if your user id is an administrator or not by doing the following:
This FAQ What userid & password do I need to install Flash Player? provides more information.
Maria
I have the same problem. I'm the Administrator on my mac (and the only profile anyway besides mandatory guest). I've confirmed I'm the administrator to and posted the same problem saying:
I got this message when I tried to update my flash "adobe flash installation failed. not enough permission to write to disk".
I followed the forums suggestions and:
- Restart my computer - no help
- Repaired my disk permissions - No help
- Uninstalled flash completely off my computer, which worked fine but then when I tried to re-install a "clean copy" the same message comes up and now I don't have any form of flash on my computer at all.
My macbook is only used by myself and I have all the admin rights.
Can anyone help?
I had the same problem with an install of both Creative Cloud and Flash. Repairing file permissions didn't help and even an OS upgrade wouldn't fix it.
In order to fix the problem I followed an error notification for the Adobe CC Installer which said that it couldn't create a folder ~/Library/Application Support/Adobe/CoreSync. This led me to check the permissions for the folder at ~/Library/Application Support/Adobe (Where ~ indicates your user directory).
Select the Adobe folder, right-click and choose "Get Info" from the menu, expand the Sharing and Permissions tab at the bottom of the window and check that your user account has Read & Write Permissions, mine wasn't listed so I added it and voila Flash now installs!
I hope that this helps!
That seems like it would fit the problem I'm having. I'm so sorry to be so dense. I'm trying to follow where the file is "~/Library/Application Support/Adobe"
But can't find any of these files. I've searched manually and then searched using the "search" function for keywords like "CoreSync" and even "Library" but it's not bringing up the files.
Could you give me some more guidance to find the file please? It certainly sounds like this could be the issue. (Sorry Chris - Thanks!!)
Hi XMattrixX,
Depending on the OS X version you have the users Library is most likely hidden (Apple made this change a while ago). In the Finder menu click on Go > Go to Folder... >
In the text field type: ~/Library/Application Support.
This will launch Finder to the correct location to view the properties of the Adobe folder.
Maria
Thanks Maria! That was really really helpful
So I followed Maria's help to find the adobe folder Chris and all the options say "read & write" (System, Admin and Everyone)
I even tried adding "Matt (Me)" to the list as "Read and Write" but still get the insufficient permissions message.
I tried restarting my computer and doing it again. Still no joy.
I thought that was so promising as well.
Hi XMattrixX,
I'd like to get some log files from you to troubleshoot further. Please see Where do I find the Flash Player installation log on the Macintosh?.
I'd be great if you could also post a screenshot of the Flash Player installer with the error message.
Thank you.
Maria
Hi Maria,
I watched the video and placed the markers in the install.log
However the issue is the install doesn't start at all so the console has nothing to record at all.
I'm really hoping I haven't just overlooked something really stupid (but at this point I'd take the shame for an answer) .
I've followed the update links and downloaded the file to install offline: "AdobeFlashPlayer_17_a_install
Here is the screen cap of the error message:
Thanks for your patience
Matt
Hi XMattrixX,
The file "AdobeFlashPlayer_17_a_install" is actually the online installer, not the offline installer. This installer downloads and installs Flash Player silently in the background.
The FAQ mentions a total of 4 files. Since nothing is being written to the install.log file the failure point is before this step. Please provide the other 3 files, FlashPlayerInstallManager.log, Adobe_ADM.log and Adobe_GDE.log? For the Adobe_ADM.log and Adobe_GDE.log files, please follow the instructions to enable verbose logging before uploading the files.
Thank you.
Maria
File 3 (I'mnot sure how much you need so selected from the end of 2014)
2014-12-13 12:27:39 +0000 IM: [install succeeded]
2014-12-13 12:27:39 +0000 IM: ---------- log end ----------
2015-01-13 23:51:54 +0000 IM: ---------- log start ----------
2015-01-13 23:51:54 +0000 IM: All install checks pass
2015-01-13 23:51:54 +0000 IM: [install started]
2015-01-13 23:52:01 +0000 FIN: [finalizer started]
2015-01-13 23:52:01 +0000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2015-01-13 23:52:01 +0000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2015-01-13 23:52:03 +0000
installer: Package name is Adobe Flash Player
installer: Upgrading at base path /
installer: The upgrade was successful.
2015-01-13 23:52:08 +0000 IM: [install succeeded]
2015-01-13 23:52:08 +0000 IM: ---------- log end ----------
2015-01-22 20:02:07 +0000 IM: ---------- log start ----------
2015-01-22 20:02:07 +0000 IM: All install checks pass
2015-01-22 20:02:07 +0000 IM: [install started]
2015-01-22 20:02:15 +0000 FIN: [finalizer started]
2015-01-22 20:02:16 +0000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2015-01-22 20:02:16 +0000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2015-01-22 20:02:18 +0000
2015-01-22 20:02:23 +0000 IM: [install succeeded]
2015-01-22 20:02:23 +0000 IM: ---------- log end ----------
2015-01-24 22:48:17 +0000 IM: ---------- log start ----------
2015-01-24 22:48:17 +0000 IM: All install checks pass
2015-01-24 22:48:17 +0000 IM: [install started]
2015-01-24 22:48:25 +0000 FIN: [finalizer started]
2015-01-24 22:48:25 +0000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2015-01-24 22:48:25 +0000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2015-01-24 22:48:27 +0000
2015-01-24 22:48:33 +0000 IM: [install succeeded]
2015-01-24 22:48:33 +0000 IM: ---------- log end ----------
2015-01-30 21:46:57 +0000
2015-01-30 22:46:55 +0000
2015-01-30 23:53:35 +0000
2015-01-31 00:53:34 +0000
2015-02-04 21:44:25 +0000 IM: ---------- log start ----------
2015-02-04 21:44:25 +0000 IM: All install checks pass
2015-02-04 21:44:25 +0000 IM: [install started]
2015-02-04 21:44:32 +0000 FIN: [finalizer started]
2015-02-04 21:44:32 +0000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2015-02-04 21:44:32 +0000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2015-02-04 21:44:34 +0000
2015-02-04 21:44:38 +0000 IM: [install succeeded]
2015-02-04 21:44:38 +0000 IM: ---------- log end ----------
2015-02-09 03:35:08 +0000
2015-03-18 09:27:06 +0000 IM: ---------- log start ----------
2015-03-18 09:27:07 +0000 IM: 1387
2015-03-19 13:57:29 +0000 IM: ---------- log end ----------
2015-03-22 13:01:24 +0000 IM: ---------- log start ----------
2015-03-22 13:01:24 +0000 IM: All install checks pass
2015-03-22 13:01:42 +0000
2015-03-22 13:01:42 +0000 IM: ---------- log end ----------
2015-03-22 13:02:46 +0000 IM: ---------- log start ----------
2015-03-22 13:02:46 +0000 IM: All install checks pass
2015-03-22 13:02:55 +0000
2015-03-22 13:02:55 +0000 IM: ---------- log end ----------
2015-03-22 13:03:04 +0000 IM: ---------- log start ----------
2015-03-22 13:03:04 +0000 IM: All install checks pass
2015-03-22 13:03:07 +0000 IM: User does not have any processes that need to be closed.
2015-03-22 13:03:07 +0000 IM: [install started]
2015-03-22 13:03:18 +0000 FIN: [finalizer started]
2015-03-22 13:03:18 +0000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2015-03-22 13:03:18 +0000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2015-03-22 13:03:21 +0000 FIN: [finalizer succeeded]
2015-03-22 13:03:25 +0000 IM: [install succeeded]
2015-03-22 13:03:25 +0000 IM: ---------- log end ----------
2015-04-05 05:40:58 +0100
2015-04-15 09:21:32 +0100 IM: ---------- log start ----------
2015-04-15 09:21:32 +0100 IM: All install checks pass
2015-04-15 09:21:32 +0100 IM: [install started]
2015-04-15 09:21:40 +0100 FIN: [finalizer started]
2015-04-15 09:21:40 +0100 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2015-04-15 09:21:40 +0100 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2015-04-15 09:21:43 +0100
2015-04-15 09:21:48 +0100 IM: [install succeeded]
2015-04-15 09:21:48 +0100 IM: ---------- log end ----------
2015-04-16 23:40:00 +0100
2015-04-17 00:44:48 +0100
2015-04-17 01:44:48 +0100
2015-04-17 02:44:49 +0100
2015-04-17 03:44:50 +0100
2015-04-17 08:02:41 +0100
2015-04-17 12:48:24 +0100
2015-04-17 13:48:25 +0100
2015-04-17 14:48:30 +0100
2015-04-17 15:48:28 +0100
2015-04-17 16:48:29 +0100
2015-04-17 17:48:30 +0100
2015-04-19 21:55:35 +0100
2015-05-15 19:49:05 +0100 IM: ---------- log start ----------
2015-05-15 19:49:05 +0100 IM: 1387
2015-05-15 19:49:08 +0100 IM: ---------- log end ----------
2015-05-22 23:57:57 +0100 IM: ---------- log start ----------
2015-05-22 23:57:58 +0100 IM: 1387
2015-05-22 23:57:59 +0100 IM: 1387
2015-05-22 23:58:03 +0100 IM: ---------- log end ----------
2015-05-28 13:28:32 +0000 ---------- log start ----------
2015-05-28 13:28:32 +0000 Failed install check: System Flash Player version is 17.0.0.169; Trying to install Flash Player version 10.3.183.7
2015-05-28 13:28:39 +0000 ---------- log end ----------
2015-05-30 00:39:07 +0100 IM: ---------- log start ----------
2015-05-30 00:39:07 +0100 IM: 1387
2015-05-30 00:39:08 +0100 IM: 1387
2015-05-30 09:15:34 +0100 IM: ---------- log end ----------
2015-05-30 09:22:02 +0100 IM: ---------- log start ----------
2015-05-30 09:22:12 +0100
2015-05-30 09:22:20 +0100 IM: Uninstall Started
2015-05-30 09:22:20 +0100 IM: [uninstall start]
2015-05-30 09:22:20 +0100 IM: user authorized
2015-05-30 09:22:20 +0100 IM: [file removal start]
2015-05-30 09:22:21 +0100 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-30 09:22:22 +0100 IM: Removed file: '/Library/Internet Plug-Ins/Flash Player.plugin'
2015-05-30 09:22:22 +0100 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-30 09:22:22 +0100 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-30 09:22:22 +0100 IM: Removed file: '/Library/Internet Plug-Ins/flashplayer.xpt'
2015-05-30 09:22:22 +0100 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-30 09:22:22 +0100 IM: Did not find file '/Users/Matt/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2015-05-30 09:22:22 +0100 IM: Did not find file '/Users/Matt/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2015-05-30 09:22:22 +0100 IM: Did not find file '/Users/Matt/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2015-05-30 09:22:22 +0100 IM: Did not find file '/Users/Matt/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2015-05-30 09:22:22 +0100 IM: Did not find file '/Users/Matt/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2015-05-30 09:22:22 +0100 IM: Did not find file '/Users/Matt/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2015-05-30 09:22:22 +0100 IM: Removed file: '/Library/LaunchDaemons/com.adobe.fpsaud.plist'
2015-05-30 09:22:22 +0100 IM: Removed file: '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2015-05-30 09:22:22 +0100 IM: Removed file: '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml'
2015-05-30 09:22:22 +0100 IM: Removed bundle receipt: '/Library/Receipts/Adobe Flash Player.pkg'
2015-05-30 09:22:38 +0100 IM: Removed file: '/Library/PreferencePanes/Flash Player.prefPane'
2015-05-30 09:22:38 +0100 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2015-05-30 09:22:38 +0100 IM: [file removal end]
2015-05-30 09:22:38 +0100 IM: [uninstall end]
2015-05-30 09:22:39 +0100 IM: Uninstall Ended
2015-05-30 09:22:41 +0100 IM: ---------- log end ----------
2015-05-30 14:14:02 +0000 ---------- log start ----------
2015-05-30 14:14:03 +0000 All install checks pass
2015-05-30 14:14:12 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2015-05-30 14:14:17 +0000 [install started]
installer: Package name is PlugIn
installer: Installing at base path /
installer: The install was successful.
2015-05-30 14:14:36 +0000 [install completed]
2015-05-30 14:14:36 +0000 [install succeeded]
2015-05-30 14:14:43 +0000 ---------- log end ----------
File 3 (sorry last one was a typo and mean to be 2)
06/03/15 16:56:17:533 | [INFO] | | ADM | | ApplicationContext | | | 120209 | *********************** ADM Workflow start. Version: 1.0.0.14s **************************
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | White listed URLs are
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | get.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | get2.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | aihdownload.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | admdownload.stage.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | admdownload.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | airdownload.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | ardownload.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | ardownload2.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | download.macromedia.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | fpdownload.macromedia.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | fpdownload2.macromedia.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | fpdownload.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | fpdownload2.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | platformdl.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | platformdl-stage.corp.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | wwwimages2.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | wwwimages.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | wwwimages.stage.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | wwwimages2.stage.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | dlmping.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | dlmping2.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | dlmping3.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | dlmping4.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | get3.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | get3.stage.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | adobetag.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | promotion.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | stats.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | sstats.adobe.com
06/03/15 16:56:21:654 | [INFO] | | ADM | | ApplicationContext | | | 120209 | Actual OS locale:'en_US', OS locale for this instance:'en_US', ADM locale : en
06/03/15 16:56:21:684 | [INFO] | | ADM | | ApplicationContext | | | 120354 | *********************** ADM Workflow start. Version: 1.0.0.14s **************************
06/03/15 16:56:21:740 | [INFO] | | ADM | | WorkflowManager | | | 120388 | Complete ADM URL after encoding: https://get.adobe.com/flashplayer/webservices/adm/?cname=AdobeFlashPlayer_17_a_install-2.dmg&bname=F...
06/03/15 16:56:22:493 | [INFO] | | ADM | | ApplicationContext | | | 120390 | sc_code : FP
06/03/15 16:56:22:493 | [INFO] | | ADM | | ApplicationContext | | | 120390 | ping : {"pagename":"ACDC_FP_ADM_Launched","channel":"ACDC_FlashPlayer","prop1":"ADM","prop2":"ACDC Downloads","prop3":"get.adobe.com","prop4":"en_US","prop5":"en_US:ACDC_FP_ADM_Launched","products":";FlashPlayer_ADM","eVar74":"","events":"event96","eVar73":"ACDC_FlashPlayer"}
06/03/15 16:56:22:847 | [INFO] | | ADM | | WorkflowManager | | | 120390 | WorkflowManager.startPrechecks for product:Adobe Flash Player isPreInstalled:false isDiskSpaceAvailable:true
06/03/15 16:56:22:850 | [ERROR] | | ADM | | ApplicationContext | | | 120390 | Error occurred while getting manifest xml at path:http://platformdl.adobe.com/adm/manifest/FlashPlayerInstaller_17_1700188.xml error: -1
06/03/15 16:56:22:850 | [WARN] | | ADM | | ApplicationContext | | | 120390 | Error in downloading. Error type : -20, extendedErrorCode : 513, errorCategory : 0, isResumable : 1
06/03/15 17:01:35:591 | [INFO] | | ADM | | ApplicationContext | | | 120209 | ping : {"pagename":"ACDC_FP_ADM_User_Cancellation_exitcode=-1","channel":"ACDC_FlashPlayer","prop1":"ADM","prop2":"ACDC Downloads","prop3":"get.adobe.com","prop4":"en_US","prop5":"en_US:ACDC_FP_ADM_User_Cancellation_exitcode=-1","products":";FlashPlayer_ADM","eVar74":"","events":"","eVar73":"ACDC_FlashPlayer"}
06/03/15 17:01:35:750 | [ERROR] | | ADM | | ApplicationContext | IPCCommunications | | 120396 | Error CB_PktID_Terminate
06/03/15 17:01:35:751 | [INFO] | | ADM | | ApplicationContext | | | 120354 | *********************** ADM Workflow end. Version: 1.0.0.14s **************************
06/03/15 17:01:35:798 | [INFO] | | ADM | | ApplicationContext | | | 120209 | Start Application Detection Id
06/03/15 17:01:35:849 | [INFO] | | ADM | | ApplicationContext | | | 120209 | *********************** ADM Workflow end. Version: 1.0.0.14s **************************
File 4
06/03/15 16:56:21:740 | [INFO] | | | | | | | 120388 | *******************start of Download****************
06/03/15 16:56:21:740 | [INFO] | | | | | | | 120388 | GDE Version is 1.0.0.1
06/03/15 16:56:22:849 | [INFO] | | | | | | | 120390 | The file to be downloaded is http://platformdl.adobe.com/adm/manifest/FlashPlayerInstaller_17_1700188.xml
06/03/15 16:56:22:849 | [INFO] | | | | | | | 120390 | Going to download the file at /Users/Matt/Library/Application Support/Adobe/.F4803B21-44EE-40B9-B3D0-8548E0918AEB/0C2126DA-C6EA-4F1A-BC59-F18B4F6820CA/31B71CE8-4584-4528-972D-D84233A8A223
06/03/15 16:56:22:849 | [INFO] | | | | | | | 120390 | Preference: Client has set the preference for single stream download
06/03/15 16:56:22:850 | [ERROR] | | | | | | | 120390 | Unable to create directory /Users/Matt/Library/Application Support/Adobe/.F4803B21-44EE-40B9-B3D0-8548E0918AEB/0C2126DA-C6EA-4F1A-BC59-F18B4F6820CA/. Error is 513 and error domain is NSCocoaErrorDomain. You don’t have permission to save the file “0C2126DA-C6EA-4F1A-BC59-F18B4F6820CA” in the folder “.F4803B21-44EE-40B9-B3D0-8548E0918AEB”.
06/03/15 16:56:22:850 | [ERROR] | | | | | | | 120390 | failed to create a dir - /Users/Matt/Library/Application Support/Adobe/.F4803B21-44EE-40B9-B3D0-8548E0918AEB/0C2126DA-C6EA-4F1A-BC59-F18B4F6820CA/ on local disk.
06/03/15 16:56:22:850 | [ERROR] | | | | | | | 120390 | failed to init the global file data for downloading
06/03/15 17:01:35:819 | [INFO] | | | | | | | 120209 | *******************End****************
This means nothing to me Fascinating. I'm a professional musician and a jazz musician at that. I imagine assuming you have no musical knowledge this is what jazz music looks like to you Hope this is what you were looking for Maria
Hi XMattrixX,
Thank you for providing the additional files. I am seeing some failures in the online installer log files (files 3 and 4). The online installer is handled by a different team and I will forward these to that team for further investigation. They may ask for more information from you after looking at the log files.
What version of OS X do you have?
Looking at the FlashPlayerInstallManager.log file, the last entry indicates a successful installation on 2015-05-30. Is Flash Player currently installed on the system and if so, what version? You can go to Installation problems | Flash Player | Mac and click the 'Check Now' button to see the version installed. If Flash Player is not installed the same Installation problems | Flash Player | Mac page contains links (at the bottom of the page) to download to the offline installers that you can try using to install Flash Player. The offline installer is the full installer and does not download anything in the background.
Maria
OS X 10.9.5
Flash 10.3.183
which link at the bottom of that page is the offline installer?
The links are in the 'Still having problems' section. For Firefox you'll want Flash Player for Safari and Firefox - NPAPI.
Maria
That sorted it!!!!!!
Thanks. Must have been an issue with online installer then. Thank you so much
Matt
Thank you! This solved my problem too!!!
Maria got there before me! - I hope that this solves your issue. It did for me.
You are my favorite person ever! My mom asked me to figure out why Flash player wouldn't install on her Mac and after trying a repair permissions, uninstall, etc. this did the trick! THANK YOU! @chris75074890
