I just bought Element 3D V2 today and i upgraded from v1.6 (which worked fine). When i create a solid and try to add the Element effect i recieve this error message.
"After Effects error: plug-in “Element.aex” could not be loaded (126). (48::46)"
I did some research and couldn't find anything except one guy on a different forum who was having the same problem. He said the problem was a corrupt openCL.dll file and he fixed it by simply replacing the file.
I believe this could be my problem i just dont know how to identify and replace the file. I have tried reinstalling the plugin etc. with no results.
Windows 10 Technical preview
Intel i7
Nvidia GeForce GT650m
8gb ram
here is a link to the other forum: AE error: "Plugin could not be loaded" » Timeclub
I browsed Nvidia's website and found a windows 10 driver and updated my graphics card. Problem solved.
Well, Win 10? It's still Beta as are any graphics drivers for it. I'm afraid you'll have to wait for either nVidia or VideoCopilot to fix it. Feel free to scour the nVidia site and install different drivers, but just replacing a DLL will do nothing, especially since Element 3D doesn't even use OpenCL and the one you mentioned thus would most likely be irrelevant.
Mylenium
i had same problem but i fix it and i made a video try and see if that works btw i am running windows 10 pro tech preview 64 bit and adobe CC2014
After Effects error: plug-in “Element.aex” could not be loaded (126). (48::46) Fix - YouTube
Just updated the graphic drivers and restarted the system
it worked
Подскажите как найти свой драйвер у меня Nvidia 630 и Windows 10 64 bit. За ранее спасибо!
You can get drivers from NVIDIA's website. www.NVIDIA.com
This bug could be fixed by updating the graphics card driver (from nvidia). Also make sure to run the latest version of Element 3D.
Delete the old installation and make a clean, new installation of the plug-in. That worked pretty well for me.
У меня такая же проблема, выдаёт какую же ошибку! Что делать не знаю
