No.
Hi Mike,
Did you got the strategy how to proceed with your requirements?.Generation of 2D barcodes for more 1 form values from the database in coldfusioj.Kindly help me.
Did you read the responses to the thread?
This is probably what you are looking for:
http://barcode4j.sourceforge.net/
Adam
I should also mention that if you are using the bar codes on PDFs instead of HTML pages, you can use the iText library to add 2d barcodes in DataMatrix and PDF417 formats. iText is a Java library for modifying PDFs. I know you said something about HTML pages, but I thought I would throw that in to the mix in case you are barcoding PDFs as well.
